DIY Routine Maintenance Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FromDownTheStreet, May 21, 2025.
  1. May 21, 2025 at 7:28 AM
    FromDownTheStreet
    FromDownTheStreet [OP] New Member
    Hello Tacoma World, new member here. Also new to doing my own maintenance, so sorry if this is a dumb question.
    I have a 21' 2.7L 2wd Tacoma (bought new) currently at 76.5K miles . I found the maintenance map from Team Oil Drop which I plan to follow starting at the 80k interval and going forward.
    That said, this past weekend I took my first stab at doing my own maintenance by replacing the front brake pads and rotors, cabin air filter, and the engine air filter. All the oil changes have been done by the dealership, they're still free, every 5-7k miles. Besides that, no other maintenance has been done, that I can remember at least.
    My Question is, in reference to the maintenance map, should I go back and do the maintenance that was missed, or should I just hit them as they come back up in the maintenance schedule? or maybe hit a select few? Thank you in advance.
  2. May 21, 2025 at 7:33 AM
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    What was missed, specifically? If it was ATF service, rear differential, then yes, I would do those ASAP.
    I will be changing the rear diff oil in two week, when I do my next engine oil change, at 17,500 miles.
    Steves104x4 and Chew like this.
  3. May 21, 2025 at 11:33 AM
    FromDownTheStreet
    Looking at the maintenance map, yeah it looks like those were missed. Along with maintenance for the transfer case and spark plugs. I am just going to hit all those things, I've been having an itch to work on my truck anyway. Thanks!
    MGMDesertTaco and Steves104x4 like this.
  4. May 21, 2025 at 12:02 PM
    MGMDesertTaco
    All that plus power steering fluid, coolant and serpentine belt.
  5. May 21, 2025 at 12:03 PM
    Barsoom
    NW GA OTP
    Be careful with spark plugs, there are lot of knockoffs floating around. Buy them from a Toyota dealer, or from a Toyota dealer on Amazon (there are a few there).
  6. May 21, 2025 at 12:04 PM
    Barsoom
    NW GA OTP
    For power steering a turkey baster works great. 3 radiator drains will replace most of the coolant.
    FromDownTheStreet[OP] likes this.
  7. May 21, 2025 at 12:05 PM
    eurowner
    eurowner Duke Sky
    Scoty
  8. May 21, 2025 at 4:12 PM
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Bravo ! on cutting the dealership service scam. Yes do anything you are over on. Tip for doing service work. Follow a routine of mapping in your mind the steps you need to complete the task. Make sure to go over everything when you are done so you dint miss anything
  9. May 21, 2025 at 4:12 PM
    wfo479
    NE Ohio
    2020 TRD Pro
  10. May 21, 2025 at 4:30 PM
    t0p_d0g
    t0p_d0g 私はタコマが大好きです
    2023 TRD SPORT 4X4 DCSB CSM, 2004 TRD OR DCSB IRP
    If you have service that was missed do it as other members have said.
