DIY Rust Removal+Prevention Plan
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ll_coolray, May 4, 2020.
  1. May 4, 2020 at 6:14 AM
    ll_coolray
    ll_coolray [OP] Well-Known Member
    Ray
    Rocklin, CA
    '17 Quicksand Taco LTD 4x4
    Been thinking about how best to do this for awhile now, searching all the threads on this forum. Here's my plan, wanted to get any input from this group before executing it, and had a few questions.
    Background: bought my '17 from a snow state NE and shipped to CA. It has some rust underneath on the frame, etc that I'd like to get ahead of. My plan:
    Day 1
    1. Use wire brush and whatever tools to knock off anything loose and grind down any visible rust spots
    2. Spray down everything with water, allow to dry for 24 hours
    Day 2
    3. Coat with cans of rust reformer
    Day 3
    4. Coat with cans of rubberized undercoating
    4a. Except exhaust, which I'll coat with high heat spray paint
    That's it, roast my plans. I won't apply Fluid Film, as I'm not in the snow much at all.
    One question I had is: during steps 2-3, what should I be avoiding spraying?
  2. May 4, 2020 at 6:19 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
  3. May 4, 2020 at 6:26 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Stay away from the rubber undercoating and I wouldn't spray bare metal with water. It'll form surface rust faster than you think. Personally since you're in CA I'd just knock any loose rust off and cover that area in POR15. And I'd do that annually and I think it'll be fine.
    CrustyTaco likes this.
  4. May 4, 2020 at 6:31 AM
    ll_coolray
    Ray
    Rocklin, CA
    Which Por15 product are you recommending?
  5. May 4, 2020 at 6:31 AM
    badkids
    badkids Well-Known Member
    ‘83 Hilux with a 2JZ
    RustBullet
  6. May 4, 2020 at 6:34 AM
    RX1cobra
    19 OR
    Any of the topcoats but POR15 was just more of an example of what I'd use. Some people say Rustbullet is betters, others Westwood chassis coat. IMO they're all so close if done right any will be fine.
    https://www.por15.com/POR-15-Top-Coat-DTM-Paint
  7. May 4, 2020 at 8:35 AM
    ll_coolray
    Ray
    Rocklin, CA
    Thanks, por15 looks like a solid product.
    Any reason to skip their recommended order of products? They seem to push:
    1. degreaser/cleaner
    2. metal prep
    3. rust prevention paint
    4. top coat
  8. May 4, 2020 at 8:59 AM
    ll_coolray
    Ray
    Rocklin, CA
    Would this work on my running boards as well? I was planning to spray with rubberized bed liner. But this seems more permanent.
  9. May 4, 2020 at 11:04 AM
    RX1cobra
    19 OR
    No reason not to but if you do some quick research you can get them same products for MUCH cheaper than they charge. I don't remember the details but the prep was some cheap acid you could get to wash concrete and rust prevent was maybe naval jelly. Do some digging if you care or you just pay their higher price and be done with it.
    Personally I'd go with the bedliner for the running boards but I'd take it to Line X and have them do it.
