DIY: squeaky leaf fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by beachbumberry, Jun 15, 2010.
  1. Jun 13, 2011 at 10:51 PM
    #141
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    I've got all the parts needed to do this mod now just need the time.
  2. Jun 14, 2011 at 10:46 AM
    #142
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    what would be the best place to jack my truck up if i dont have a hitch receiver?
  3. Jun 14, 2011 at 11:28 AM
    #143
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  4. Jun 14, 2011 at 1:36 PM
    #144
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    yea but the frame raises up after it passes the rear suspension...and i dont have a hilift jack
  5. Jun 15, 2011 at 9:29 AM
    #145
    Simms65
    Simms65 Well-Known Member
    David
    WV
    '16 Quicksand O/R M/T
    Stack some 2X4s, 2X6s, 4X4s, 6X6s, or whatever other lumber you have laying around to make a platform. I used a regular shop jack and put two pieces of 4X4 on top of it to achieve the proper height. Just make sure your front wheels are chocked, and your lifting surface is as stable as possible.
  6. Jun 15, 2011 at 9:53 AM
    #146
    VooDoo
    Carter Ivey
    '06 DC LB PreRunner
    yea thats what im gonna do, thanks for the help!
  7. Jun 16, 2011 at 5:27 AM
    #147
    BransTaco
    BransTaco Well-Known Member
    Brandon
    North Georgia
    08 Silver Taco TRD Sport
    K&N, Tinted Winders, black'd emblems, amp'd sound system, custom sub, washed
    ahhh finally a way to get rid of the friggin squeak...nice write up. ..
  8. Jun 16, 2011 at 5:57 AM
    #148
    OmahaStylee
    OmahaStylee Beating Anorexia since 1976
    Omaha, NE
    01 DC TRD
    FRONT: Toytec CO's & diff drop BACK: AllPro standard leaf kit with Bilsteins and axle shims
    I've developed "the squeak" over the past few months... I had no idea up until now that it was a common issue.
    Big THANKS for a great write-up!!!
    ...now I just need to find time to do this.
  9. Jun 21, 2011 at 9:38 AM
    #149
    Scooter
    Scooter Canadian Member
    Manitoba, Canada
    08 Double Cab TRD Sport Short Box
    Pop n Lock Power Tailgate Lock, Bak Flip Tonneau Cover, Factory DLR installed, Defrost with A/C Off, EZ Down Tailgate Damper, Code Alarm Security System with Remote Starter, Rear Spring TSB, Ming rust proofing & paint treatment, 3M fabric protector, Cargo Mat, Scanguage II, DYI Illuminated 4X4 Switch, Versa-Gate box extender & cargo divider, Toyota Roof Rails, Grom USB Audio adapter with bluetooth, LED Bed lights, OEM Backup Camera with LCD Display Mirror
    I just developed the squeek yesterday. It's coming from the right rear. It only happens when I accelerate from a stop. I'm going to try this fix. I had the rough ride TSB done, so I have 4 leafs , and there are 3 leafs at the C-clamps. Do I need 2 pieces of inner tube at each C-clamp, one between the middle and top leafs, and one between the middle and bottom leafs?
  10. Jun 21, 2011 at 9:54 AM
    #150
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Update :
    The chain lube worked for 3 weeks
  11. Jun 30, 2011 at 10:09 AM
    #151
    OmahaStylee
    Omaha, NE
    01 DC TRD
    UPDATE: I found time to do the work last friday (6/24/11), but I'm still squeaking :(
    1st attempt: added tubes in both gaps at the FRONT of the leaf packs
    2nd attempt: added tubes in both gaps at the BACK of the leaf packs
    ...still gettin' the "squeaky squeaky" at low speeds (rolling <15mph)
    Am I doing something wrong? chasing the wrong squeak source, perhaps?
  12. Jun 30, 2011 at 12:04 PM
    #152
    beachbumberry
    beachbumberry [OP] Well-Known Member
    andrew
    fl now, tx native
    05 sr5 4x4 access cab
    leveling kit, american racing rims, push bar, nerf bars
    did you take the tubes all the way to the ends? that's where the leafs squeak against eachother.
  13. Jul 2, 2011 at 7:43 AM
    #153
    freightman
    freightman Member
    whittington
    denham springs louisiana
    07 prerunner sr5
    thanks mr wippersnapper for the link i will try this and let you know
  14. Jul 8, 2011 at 2:35 PM
    #154
    Pitbullhunting
    Pitbullhunting Well-Known Member
    Florida
    Tacoma TRD Offroad
    Work in progress
    Just did this to my Tacoma. WOW! Thats amazing. Atlast a fix to the annoying squeaking springs. Thanks for the write up. Great job.:yay:
  15. Jul 10, 2011 at 5:09 PM
    #155
    2chains
    2chains Well-Known Member
    Calgary, Alberta
    2010 Tacoma DC LB 3" Revtek lift
    3" Revtek lift, k&n 63-9025 intake, tailgate debadge, OEM Bed mat, decals gone. helo black max 6 bs 4.5 os-12,duratrac 285 70 17,smittybilt light bar, kc slimlites, pioneer pb3300 bt, window tint, weathertech digfits, raider lorider elite tonneau, at2525xl,
    2010 with 30,00o km I've been squeaking badly for 2 weeks now,especcially when standing on the bumper or getting out of the driver side... it's driving me crazy. I didn't realize it was a common problem. thanks for posting!
  16. Jul 18, 2011 at 7:04 AM
    #156
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    2008 Tacoma Sport 4x4
    low range leveling kit
    i misunderstood...which happens a lot....:eek:. ya'll are talking about placing it at the ends of the leaf springs and not towards the center. got it!
    that said...how tight are the u-bolts suppose to be torqued....85ftlbs? i jacked up my truck and could not seperate my leaf springs...so I loosened my u-bolts to attempt to help w/the process.
    thanks,
    al
  17. Jul 19, 2011 at 12:22 PM
    #157
    beachbumberry
    andrew
    fl now, tx native
    You should NEVER retorque u-bolts, they are a 1 time use thing, after they are loosened they lose thief strength. When you jack the truck up, you are just lifting it up enough to take the weight off the springs... Keep the tires actually on the ground, but just barely... Trick I learned with pullin mount pins out of jet engines actually!
  18. Jul 20, 2011 at 2:20 PM
    #158
    Ronin
    Ronin iTaco
    Al
    Rockwall, Texas
    Thanks for the response beachbumberry.
    Another question. Wouldn't the steel of the leaf spring cut through the tube or plastic?
    Thanks,
    Al
  19. Jul 20, 2011 at 9:55 PM
    #159
    hogfan1978
    hogfan1978 Well-Known Member
    Nacogdoches, TX
    08 TRD Sport 4x4 DC LB
    Thanks for the good idea!!
    Just did this tonight. I used a heavy duty mountain bike tube from WalMart. The only bad thing was that it had the green slime in it that I had to clean off - a little gasoline and no problem. I was able to do it without jacking it up too.
    I folded the tube over itself to make the pad twice as thick - which was then approximately 6 mm prior to getting squeezed between the leaves. i used gorilla glue on the front contact and no glue on the back contact on both sides.
    It looked like it should hold for quite some time. I also don't do any major offroading - just some cow pasture driving, so I don't think it will get much wear. We'll see...
  20. Jul 20, 2011 at 10:55 PM
    #160
    OZ-T
    Peter North
    British Columbia
