DIY tie rod replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by sgeezy, Jun 27, 2011.
  1. Jun 27, 2011 at 4:44 PM
    sgeezy
    sgeezy [OP] Active Member
    Shelton
    PB ARK
    SCRATCH n SNIFF
    2.5" rough country lift, Billy 5100's up front, 31X10.50x15 BFG KM2 tires, 15x7 Black Crager 397 series soft 8 wheels. One 15" kicker L7 Subwoofer in ProBox. 2000 watt volfenhag amp. K&N Cold air intake. And 266K miles
    :confused: I've looked and looked and looked but i can not seem to find a picture or a thread on DIY tie rod replacement.
    Question is, drives side outter tie rod. Does the bolt go up through the lower ball joint piece like the passenger side or down through the top?
    Made mistake of not paying attention when taking it apart. :(
    Replaced LBJ after it snapped and now i cant drive over 30 cause the steering is so bad and my tires squal when i turn slightly. If this sounds like there is another problem let me know. left tire is straight, right tire is toed WAY in.
  2. Jun 28, 2011 at 6:00 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    From the bottom up through the knuckle.
    The driver's side and passenger's side are identical.
  3. Jun 28, 2011 at 10:48 AM
    sgeezy
    Shelton
    PB ARK
    SCRATCH n SNIFF
    Awesome, I got a new one ordered and putttin it on today
  4. Jun 28, 2011 at 10:56 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Wait. They go on idendical, but IIRC they are side specific.
  5. Jun 28, 2011 at 6:09 PM
    sgeezy
    Shelton
    PB ARK
    SCRATCH n SNIFF
    well on my 96 v6 4x4 the sides are identical and side specific, fixed my problem. Marked where the nut was on the old one and put the new one on. turned my wheels straight and adjusted accordingly.
