DIY Video - Front Camera Install and Demo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iampraneel, May 7, 2019.
  1. Aug 26, 2019 at 6:53 AM
    #81
    MaTaco_4x4
    MaTaco_4x4 Well-Known Member
    2018 Tacoma Sport DCLB
    Aft market grill and $21 garnish.
    The camera is under the "OT"... Tilted so the bumper is just barely off screen.
    Pro-Taco[QUOTED] likes this.
  2. Aug 26, 2019 at 9:18 AM
    #82
    flipnidaho
    flipnidaho Well-Known Member
    2001 Tacoma Double Cab TRD
    I plan on installing mine a little bit right or left of center as well (TRD Pro grill). Do you have a pic of what the video looks like when it's mounted off center like that? I'll use my front camera mostly for parking and to make sure that the front is all clear of kids and animals before pulling out.
    Pro-Taco likes this.
  3. Aug 26, 2019 at 9:18 AM
    #83
    Pro-Taco
    Pro-Taco Well-Known Member
    Lou
    Commiefornia
    2019 OR DCSB 4X4 Prem/Tech Cement
    All TRD Pro parts
    Thank You.
    MaTaco_4x4[QUOTED] likes this.
  4. Aug 26, 2019 at 9:36 AM
    #84
    MaTaco_4x4
    It looks completely centered, just like the off-center rear camera.
    I do wish I could move the guide graphics on the Entune like I can on newer heads. The steering indicator would be useful too.
    That's a different project though. I'm thinking Rock64 single board computer, 10" OLED capacitive touch, full topo and street mapping/nav, full 360 DVR camera system, builtin GSM data and wifi AP, and an epic, if mildly disturbing, big-butts porn stash burned right into the firmware.
    MrBrooks likes this.
  5. Aug 26, 2019 at 9:45 AM
    #85
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
    Just point me to your crowd source link and I'll be first in line and a willing beta tester!
  6. Aug 26, 2019 at 9:52 AM
    #86
    flipnidaho
    Thanks. I'm gonna tackle it on Friday. About how long did it take you to do the install?
  7. Aug 26, 2019 at 9:53 AM
    #87
    MaTaco_4x4
    Why wait on me?
    I haven't checked, but the Adafruit touchscreen will probably fit in the existing bezel. A Raspberry Pi 4 will easily do most/all of what I described. A 2TB solid state disk is the only pricey bit, but 2TB of big-butt porn makes that a wise add-on.
  8. Aug 26, 2019 at 9:59 AM
    #88
    MaTaco_4x4
    40 minutes, I guess. 10 of that was making a 4mil shim to compensate for mounting height. That probably doesn't matter anyway.
    Another hour for routing wire, hooking up the smart switch, wondering should I build a 4-channel switch instead, deciding no because too many projects as-is..
  9. Aug 26, 2019 at 10:08 AM
    #89
    HelloMyNameIs
    For those prices I would prefer my big butt porn be on three 1TB drives in a RAID 5 config, for uh, posterity's sake.
  10. Aug 26, 2019 at 10:10 AM
    #90
    MaTaco_4x4
    Get it?
    POSTERITY, CORAL!
  11. Aug 26, 2019 at 11:42 PM
    #91
    Rjwz28
    Rjwz28 Well-Known Member
    Rob
    Big Island of Hawai’i
    2019 TRD sport
    Mostly stock. Icon wheels, running boards, sounds, custom grill, front camera.
    I got mine working now thanks to the OP with his great video. I mounted mine under the license plate holder as here in Hawaii it’s illegal to run without the front plate. The one question I have is can the forward view be left on indefinitely instead of just 30 seconds as in case you go off roading and want to see where you are going and not have to hit the mode button every time it goes off?
  12. Aug 27, 2019 at 5:53 AM
    #92
    MrBrooks
    MrBrooks Well-Known Member
    Midwest
    2018 DCSB - 2021 Rav4
    Yes double tap the mode button & then up arrow to front camera holding it down till you hear a beep. It will lock on to the camera. From there you can switch back & forth without them turning off
  13. Aug 27, 2019 at 12:01 PM
    #93
    Rjwz28
    Rob
    2019 TRD sport
    Thanks!
  14. Aug 28, 2019 at 9:00 AM
    #94
    Ryan Limkoe
    Ryan Limkoe Member
    Red 2019 Tacoma Access Cab with ARE LSII bed cap
    I just spotted this and subscribed to the YouTube video. It looks very interesting and later on I'll study it in detail.
  15. Aug 30, 2019 at 3:02 AM
    #95
    flipnidaho
    I finished mine last night. The hardest part is punching through the firewall.
    MrBrooks and MaTaco_4x4 like this.
  16. Aug 30, 2019 at 4:32 AM
    #96
    MaTaco_4x4
    That's reeeally close to the TSS's receiver portion of the radome. If you get intermittent PCS OFF light, you can move it a couple of inches left/right and it should work again.
    It looks really good there.
  17. Aug 30, 2019 at 5:59 AM
    #97
    flipnidaho
    So far so good in that position. It's easy enough to move to the left or right without affecting the view out of the front (heck, our backup camera is also off center).
  18. Sep 2, 2019 at 11:41 AM
    #98
    trifox13
    trifox13 Member
    2019 TRD OR Access Cab
    Question on routing through the firewall. It appears you have to pierce the rubber gasket with a hole large enough for an rca plug. Or is it possible to have it come out directly where the hood latch cable runs through the gasket? And to confirm on the TopTier camera, you can use the red wire on both ends for the power for the camera. Thanks in advance.
  19. Sep 2, 2019 at 12:11 PM
    #99
    MrBrooks
    Midwest
    I pierced the gasket with a coat hanger style rod & looped the camera cable with electrical tape onto the rod so the RCA jack wasn't the leader. Wasn't too bad of a challenge.
    Yep used the red wire on both ends of the TopTier camera cable for power to the kit. Worked great!
  20. Sep 2, 2019 at 12:20 PM
    #100
    trifox13
    trifox13 Member
    Thanks MrBrooks!
