DIY Video - Front Camera Install and Demo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by iampraneel, May 7, 2019.
  1. Dec 19, 2020 at 5:40 AM
    #161
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I've had the setup for about 8 months. Had the camera go black but then it self healed. Someone previously posted this happened to them also. Also have had 2 or 3 instances where the TSS activates and say "BRAKE" for a second or 2. My camera is mounted right in the middle above the sensor in a PRO grille on my Sport. I've only had the truck for a little over a year so TSS issue may or may not be attributed to the camera or even the install area because of how you have to drill the grille to get the camera in the "center" I may just go in and weatherproof that area kinda the way that TSB does.
    An FYI for anyone installing the camera, don't put it below your bumper, like on your license plate. To get full effectiveness of the camera you want to be able to see your bumper
    CobraMisfit and DES2009 like this.
  2. Dec 20, 2020 at 1:54 AM
    #162
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Good to know. I'm mounting mine dead center of the tss on my Sport with the Pro grill. Did you have to remove the grill in order to drill? Does it sit flush? Pics if you have them please.
  3. Jan 25, 2021 at 12:07 AM
    #163
    iampraneel
    iampraneel [OP] Well-Known Member
    2016 DCSB TRD Sport 2WD
    How did your install go?
  4. Jan 25, 2021 at 12:37 AM
    #164
    Sand_In_My_Taco
    Sand_In_My_Taco Well-Known Member
    NOR*CAL
    2025 1794 Tundra TRD-OR
    So this has been bugging for two months or so and I've just gotten around to addressing it.
    I have this setup, and when I put the truck in reverse, my rear camera doesn't automatically come in like it used to.
    I can still press mode 2x and get both cameras to come on, however its an extra step that wasn't needed before.
    I've taken the dash apart and unconnected/reconnected the module, still doesn't display rear cam on reverse.
    Has anyone else ran into this issue, or have any ideas? I don't look forward to trying to warranty it, as the seller requires you to have the original box and packaging in order to accept the warranty.
  5. Jan 25, 2021 at 12:50 AM
    #165
    VaToy
    Parts Unknown
    Install went great, took about an hour. No issues, simple plug and play with the hardest part was fishing the wires. I didn't take the grill out, I measured for the spot to drill the hole and used a small drill bit as a guide.
  6. Jan 26, 2021 at 11:52 PM
    #166
    iampraneel
    I haven’t had that issue. What happens when you take the car solutions unit out of the equation? Does your reverse camera function as normal?
    VaToy likes this.
  7. Jan 27, 2021 at 2:00 AM
    #167
    VaToy
    Parts Unknown
    What camera did you use in the front? Did you cut the wrong wire or did you cut the cut the wire at all? I have the Natika and it requires you to cut the white wire to use it as a front camera. Did it work fine at first then just started acting up?
  8. Jan 31, 2021 at 5:32 PM
    #168
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Now you got me wondering if you could put a dash cam behind the grill instead of a camera.
  9. Jan 31, 2021 at 5:39 PM
    #169
    [bbs]
    [bbs] New Member
    '21 Army Green TRD Offroad
    I would think that you would be reducing camera field of view. And also have more obstructed views due to the lower height. And lastly, most cameras probably can't protect against road dirt, grime and moisture.
    markram likes this.
  10. Feb 28, 2021 at 10:44 AM
    #170
    iampraneel
    has this been resolved for you?
  11. Feb 28, 2021 at 2:56 PM
    #171
    Sand_In_My_Taco
    NOR*CAL
    Nope. Works fine 2x mode press, and can swap front/rear, but I do not get camera on with reverse.
    I ordered through their website, so I doubt I can get a warranty w.o box etc etc.
    I have yet to pull the dash to try w.o the unit hooked up.
  12. Mar 2, 2021 at 2:54 PM
    #172
    Dazed
    Dazed Well-Known Member
    2016 TRD Sport 4x4 DCLB
    Has anybody done any work on making these front and rear cameras into recorders like a dashcam? I tried searching the site for any info, but I couldn't find any info.
  13. Mar 27, 2021 at 1:08 PM
    #173
    iampraneel
    I think the angle might be too low to capture anything useful but you could try to split the signal into a device that can record. Not sure if that would work but it might be worth a try.
  14. Mar 27, 2021 at 7:02 PM
    #174
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Based on using my anytime front and rear cameras I think the depth of field/field of view of something like that wouldn't work very well. Basically if there's a car 50' behind you it might as well not be there whereas dedicated dash cameras can capture stuff further out.
  15. Mar 27, 2021 at 7:07 PM
    #175
    Dazed
    It will probably be more for insurance purposes more than anything else. Any box that I install will have to get passthrough to the head unit, get power from the truck uninterrupted, and record on loop. Not trying to make a highlight reel, but it will be better than nothing for insurance. I was looking at the garmin dash cam tandem, but it looks like it records more of the interior than anything else out the rear window.
  16. May 14, 2021 at 11:32 PM
    #176
    iampraneel
    i agree
  17. Aug 7, 2021 at 10:30 AM
    #177
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Agree, been looking for a recording option for the rear camera as well.
  18. Aug 7, 2021 at 11:21 AM
    #178
    poopshute
    poopshute Well-Known Member
    Colorado
    2017 Tacoma TRD Pro Storm Trooper
    I know it sounds like a pain but I would recommend using the rear and front cameras for their intended purpose (visual spotting for parking, 4wheeling, etc…) and install dash cameras to record stuff front and rear. The angle of the front and rear bumper cameras really don’t provide a good angle to record anything useful. Just my .02 though.
  19. Aug 12, 2021 at 7:12 PM
    #179
    Dazed
    Oh yeah, I don't plan on moving the cameras or interrupting their ability, hence why I want to use a pass through. It's just a little bit of insurance in case say somebody backs up into my truck and says that I rear ended them. Doesn't have to be great resolution doesn't even have to be good. Just enough to prove that they are at fault.
    poopshute[QUOTED] likes this.
  20. Sep 21, 2021 at 3:28 PM
    #180
    cocephus
    cocephus Well-Known Member
    Joe
    2021 Cement Tacoma TRD Sport
    This is awesome and will be my next mod. Thank you for the video!
