DNX5120 question
Discussion in 'Audio & Video' started by Salsashark, Mar 19, 2009.
  1. Mar 19, 2009 at 8:02 PM
    Salsashark
    Salsashark [OP] Well-Known Member
    Idaho
    07 TRD Offroad
    So i bought the DNX5120, "installed" it the ipod cable, and the metra TYTO-01 kit. Also tried the Pac Swi Jack, but couldn't get the piece of shit to work so i removed it. Anyways, and i posted this in another thread, when the music is playing, it seems to go up and down...or from muffled to unmuffled, its not much difference, but enough to notice, especially at higher volumes. Doesnt matter if truck is on or not, or moving. I pulled the goddamn thing out again, and checked the wires, everything seemed ok. Not sure what to check, doesnt seem to matter if the Ipod is playing or the radio, did the updates for kenwood and the garmin...not sure if i should dick with it more, try sending it back or have someone who knows what they're doing, do it.
  2. Mar 19, 2009 at 8:19 PM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Could be that your speakers cannot carry the RMS versus the wattage and it is slipping back and forth. Your RMS is a constant or continuos cicuit to where as wattage is not which is why you will usually see that the RMS is lower than the wattage rating. I could be worng, but if you are still using stock speakers you may be experiencing this. just an idea. Also does yours ystem have the JBL stereo and if so did you get the adapter for the amp? I don't think you can install without that. I have the same radio and have had no issues. May also have a bad unit, happens. Food for thought.
  3. Mar 19, 2009 at 8:29 PM
    Salsashark
    Idaho
    07 TRD Offroad
    Yeah, got the metra "Toyota Amplifier Interface", since i have/had JBL system.
    I had it working fine for a couple of days, had it in just no dash kit, while i was trying to figure out the pac swi jack, which ended up being wired wrong...but still couldnt get it working even after i rewired it. ANyways i dont recall the volume issue before, with the jack in, just now, but i pulled it out today and everything was tight. bleh
  4. Mar 20, 2009 at 9:06 PM
    Blackened Taco
    Tony
    Virginia
    Well your speakers will hande the load no problem with the JBL system. You had your radio bolted in just no faceplate right? You may want to call the place you bought it from. As long as your radio wasn't bouncing around inside the dash. I can't see anything else on that would have brought harm.
  5. Mar 26, 2009 at 6:35 PM
    Salsashark
    Idaho
    07 TRD Offroad
    Sorry for delay, was out of town, no it was bolted down when i had it on w/o the faceplate. I took it all out again, and rewired it, no change. I did put the stock stereo in and turned the stereo up, Kenwood seemed kinda quiet. Anyways no real change...i guess ill dick around with it a bit more, had a CD in earlier and it didnt fade in and out, didnt sound that great though. Maybe its the ipod conector. Either way it seems to just be the front speakers.
  6. Mar 28, 2009 at 12:14 AM
    95tojo
    95tojo IG @jkthomp01
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    does the jbl box that came with the harness have a seperate "volume" control on it ? i know the gmos-04 do for chevy vehicles . . . also may be a bad harness . . . or bad rca's . . . i'm assuming your running it through the front and rear rca ports ? the kenwood only has 2v pre outs . . .
  7. Apr 1, 2009 at 11:54 AM
    Salsashark
    Idaho
    07 TRD Offroad
    Well called the place i bought the unit from, they said it sounded like the harness. So i called them, and they had me reset it, didn't work...gonna try it one more time. Have to unhook the battery for 10 minutes then turn the truck to on then off 3 times. If that doesn't work metra told me to call them back. May just of gotten a bad harness, the guy i talked to initially said they are all the same thing regardless of the manufacturer. Guess next thing depending on what metra says is purchase another harness see if that remedies the issue. ><
  8. Apr 19, 2009 at 8:24 PM
    Salsashark
    Idaho
    07 TRD Offroad
    Well the place on Ebay i bought the harness from traded me for another. They claimed to have never heard of the problem, but i got a new one anyways, i had to pay s/h both ways, but the new harness seems to have fixed the fading problem.
