Do all 2nd Gen Tacos come with a tranny cooler?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by r12rex, Aug 21, 2009.
  1. Aug 21, 2009 at 12:17 PM
    r12rex
    r12rex [OP] Well-Known Member
    Cleared headlights, Black emblems, Painted black valence on front bumper, 2.5" 5100 Billys front, 1.5" AAL rear, Satin black TRD O/F wheels with 265/75 16 Definity M/T, Spidertrax spacers
    Guys,
    I'm researching the towing package for 2nd Gen Tacos as my 05 Prerunner was not optioned with it.
    I've read threads stating that the "Pink" fan clutch indicates a towing package installed on the taco. My Taco has the Pink fan clutch and there is a smaller radiator that sits in front of the main radiator. Is this the tranny cooler?!
    There are members with the factory towing package that have the pink fan clutch and there are guys like me who do not have the towing package with the same pink fan clutch.
    What does the OEM tranny cooler look like?! Guys with the factory towing package can you show me your tranny cooler?
    Thanks!
    Kind Regards,
  2. Aug 21, 2009 at 12:41 PM
    98tacoma27
    Ben
    Not Beech Creek
    If it has two lines that run back to the tranny then it is the cooler.
  3. Aug 21, 2009 at 12:56 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Also, look underneath your oil filter (on 4.0L)...
    If you see something similar to this (supplemental engine oil cooler)
    [​IMG]...
    Then, yes...you have the towing package.
  4. Aug 21, 2009 at 1:00 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    the trans cooler is behind the grill underneath the horns. its the small black cooler. If you have the tow package you have both of them, but you only get the trans cooler if you have an automatic.
  5. Aug 21, 2009 at 8:00 PM
    JKD
    JKD Well-Known Member
    I wish I could find that engine oil cooler, or its equivalent, for less than Toyota OEM prices.
  6. Aug 21, 2009 at 8:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  7. Aug 21, 2009 at 8:04 PM
    Razorecko
    Razorecko Well-Known Member
    '09 Pyrite DCLB TRD Supercharged
    setrab makes the best coolers.
  8. Aug 21, 2009 at 8:29 PM
    JKD
  9. Aug 21, 2009 at 8:38 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    no your right, checked this out when i installed my $30 oem oil cooler....:D
  10. Aug 21, 2009 at 8:41 PM
    BUDSHAD
    BUDSHAD Smartass Killa
    Chad
    Macon, Ga.
    08 TRD 4X4 SR5
    Redline D6 tranny fluid. Redline gear oils in front and rear diffs. Bug shield and rain gaurds. Mossy Oak seat covers until I can afford the Wet Os.
    Yes you have the tow pack.:)
  11. Aug 21, 2009 at 10:17 PM
    r12rex
    Thanks guys,
    I don't have the small black cooler under the horns though. I do have the engine oil cooler though...
    Weird...
    Kind Regards,
