Do Billisteins require occasional adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Les Callahan, Jun 27, 2012.
  1. Jun 27, 2012 at 10:42 PM
    Les Callahan
    Les Callahan [OP] Member
    Seahorse
    Orlando
    08 PreRunner SR5
    Billi 1500 front, Rear TSB , Grillcraft grill, NOBAMA bumper sticker, Wet Okole front seat covers, reversed floor mats (flipped them over, now have durable black mats)
    About a year ago I had front billisten 5100's installed and they were
    set at the 1.75 or whatever was suggested to level the front of my
    2008 PreRunner. The truck immediately appeared level. In the past
    4 months it appears that the truck is tilted forward again.
    Do these shocks require periodic adjustment? Any ideas?
  2. Jun 27, 2012 at 10:54 PM
    boss1041
    boss1041 Well-Known Member
    chad
    valdosta, georgia
    07 dc 6 speed trd or, 95 auto
    The springs have settled. I have mine set the same. Adjustment not required unless you want to bump it on up to 2.5 which I believe is the next setting or I think u can change out the stock coils for ebaich or ome coils then just use the coils to carry the weight for the lift.
  3. Jun 27, 2012 at 11:14 PM
    Les Callahan
    Seahorse
    Orlando
    08 PreRunner SR5
    When you say the springs have settled, do you mean the front springs?
    If I don't want to go as high as 2.5 what are my other options.
    I am not mechanically educated enough to understand your response.
    I apologize, could you put it in more laymans terms.
    Thanks,
    Les
  4. Jun 28, 2012 at 12:16 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    The shocks don't need adjustment; the front springs have probably just settled. If you don't want to go to 2.5" then get the eibach coils. Think they give you just under two inch with stock shocks or 5100s set to zero.
    Ome 885x's will put your prerunner just over 3" with your 5100s set to 0.
  5. Jun 28, 2012 at 12:23 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    5100's "lift" the front of the truck by changing where the coil spring sits on the shock. The part that the coil sits on can be moved to sit in three different rings on the shock body, from 0-1.75-2.5.
    So, the shock itself isn't doing the lifting. By changing how high the coil sits, you're compressing the spring to lift your truck
    But, over time, since the coils were not made to be constantly compressed, yours have settled a bit, so your truck appears to have dropped a bit in the front.
    As suggested, I'd recommend grabbing a set of OME or eibach springs, and having a shop set your coil seat to "0", or stock. This should give you 1.75" of lift back, with less sag over time, and a better ride
    hope this helps
  6. Jun 28, 2012 at 6:01 AM
    boss1041
    chad
    valdosta, georgia
    ^^^this is what I was meaning but couldn't think properly at 2am sorry my post was kinda vague
  7. Jun 28, 2012 at 1:05 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    How is it compressing the spring? If you change the mount point 2" up on the shock body which in turn raises the top and the truck 2" where is the compression? :confused:
  8. Jun 28, 2012 at 4:31 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    X2:confused: it would seem to be the other way around. I would more incline to think the shocks have settled and needs adjusting or replaced.
  9. Jun 28, 2012 at 5:20 PM
    boss1041
    chad
    valdosta, georgia
    each time you move up a setting on the shock you compress the coil more which in turn is the main reason the higher setting have a rougher ride
  10. Jun 28, 2012 at 5:33 PM
    fvtalon
    fvtalon Well-Known Member
    Southern BC
    07 DC TRD/Yamaha
    285/65/18 BFG ATs on MKWs Leer Cap
    Shocks or struts don't hold the vehicle up. They don't support any weight, they just control the motion of the spring. The spring is what supports the weight of the vehicle. That said yes they top out by themselves so they provide some support but you're talking probably <50lbs each which is negligible.
    The Billys do compress the spring because as you move the bottom ring up remember that the top hat can only extend so far so you keep adding compression to the spring because the space available to the spring gets smaller.
    For the OP if you had 1.75" to begin with and the springs have sagged 3/4" you can go up to the 2.5" setting on the billys and be back at 1.75". What happens to springs is they eventually lose their 'springy-ness' as they sit loaded up. A spring that starts out 8" long and is compressed to say 5" will over time settle out and eventually if you take the load off maybe it will will only extend to 7".
