Do Deavers squeak like Dakars?
Discussion in 'Suspension' started by OkeyCodyOh, Jan 27, 2021.
  1. Jan 27, 2021 at 12:05 PM
    OkeyCodyOh
    OkeyCodyOh [OP] Well-Known Member
    Cody
    2020 Off Road MGM
    I've had enough squeaking from my dakar medium pack, it just constantly sounds like im having sex on an old mattress. I have a RSI Smartcap and other goodies that's going to be adding more weight in the back. So I was looking at upgrading to the Deaver Exp Series stage 2, i've read some people did the swap from dakar and deaver and didn't have any issues since. are there more people here on TW that can confirm this?
    I've tried spraying the hell out of them to get any dirt out, covered the bushings in liquid grease to try and lube it which is the only thing that changes the sound to just being not as loud. Is there anything else to try?
    Gunshot-6A likes this.
  2. Jan 27, 2021 at 12:06 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Confirmed. Deavers do not squeak like the Dakars.
  3. Jan 27, 2021 at 12:06 PM
    geekhouse23
  4. Jan 27, 2021 at 12:15 PM
    OkeyCodyOh
    Cody
    2020 Off Road MGM
  5. Jan 27, 2021 at 12:18 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    If you want them quiet you need chassis grease between the leaf packs
    This means off with u bolts, loosen center pin, separate leaves and apply everywhere
    Spraying doesn’t do the job
    Fahrenheit, TVH475 and OkeyCodyOh[OP] like this.
  6. Jan 27, 2021 at 3:43 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I contacted ome about this, they sent me all new wear pads & liners free, I put the new wear pads in with grease & haven't had a squeak since, probably 15,000 miles now without touching them again
    OkeyCodyOh[OP] likes this.
  7. Jan 28, 2021 at 10:49 AM
    FishN'Taco
    FishN'Taco Well-Known Member
    lucas
    San Diego, CA
    18 TRD OR DCSB
    Fox 2.5 Ext Travel w/ Adj Reserviors (3") ACCUTUNED Camburg Uniball UCA Deaver u402 stage 1 Leer 100XQ Front Runner Slimline II Rack Baja Designs Onx6+, SQ-Pro, SQ-Sport Switchpros 9100 285/70/17 Falken AT3W on 17 Method 305 NV RIGd Ultraswing Powertank 10lb
    no squeaks here, u402 stage 1. about 10k on them now
    OkeyCodyOh[OP] and geekhouse23 like this.
  8. Apr 14, 2021 at 9:36 PM
    Rbcb01
    Rbcb01 Active Member
    2017 TRD Offroad
    I have u 402 stage 1 with around 500 miles on them bushings already squeaking bad
    Used super lube silicone grease on the bushings, that’s what all pro, first king and total chaos recommend for poly bushings
    I noticed that the bushings did not have to be pressed in on one side they were kind of loose
    I can still feel the grease but they’re squeaking
    I will try to buy the greaseable shackle bolts but if that doesn’t help I’m replace bushings with rubber ones
    Deaver could have done a better job on these they did not even file all the ends of the leafs where they cut the diamond tips
    A lot of burrs left
    Poor workmanship
    They do ride good though
