Do double din Alpine headunits fit 1st gens?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cutter_, Jan 14, 2020.
  1. Jan 14, 2020 at 8:43 PM
    Cutter_
    Cutter_ [OP] I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
  2. Jan 14, 2020 at 8:45 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I honestly didn't didn't think that ANY double-DIN head unit would have fit issues in a first gen...
  3. Jan 14, 2020 at 9:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Did you use the "ears" from your factory stereo?
    Unless your Alpine came with additional Japanese mounts, you'll have to reuse the factory mounts.
    Some have reported needing to grind off a corner on one of the mounts depending on the stereo they used.
  4. Jan 14, 2020 at 9:19 PM
    Cutter_
    Ears from factory, I think I will have to grind off a corner
    Kwikvette[QUOTED] likes this.
  5. Jan 14, 2020 at 9:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So just as I suspected; just notch that corner off or whatever you have to do and you should be good.
  6. Jan 14, 2020 at 10:34 PM
    jdmstuff
    jdmstuff Well-Known Member
    Derrick
    Torrance, CA and Las Vegas, NV
    '18 TRD OR DCSB AT, '08 TRD Sport DCSB AT, '03 TRD 3.4l 4x4 MT Supercharged
    Are you referring to the locating tabs on the stock radio brackets? Just bend them flat and match up the holes on the bracket with the ones on the side of the new headunit. It should fit fine, but if the screen isn't motorized, i.e. able to adjust angle, it might be a little difficult to see in certain light during the day. Otherwise, it will fit fine and you shouldn't have to trim any of the plastic panel that surrounds the radio area for it to fit.
    Cutter_[OP] likes this.
