Do Eibach springs require alignment?
Discussion in 'Suspension' started by Zac808, Nov 2, 2009.
  1. Nov 2, 2009 at 2:56 PM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Do Eibach springs require alignment on truck?
  2. Nov 2, 2009 at 3:11 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    I would say if you change the heigth any way up or down it needs to be aligned.
  3. Nov 2, 2009 at 3:19 PM
    311offroad
    311offroad Stock Taco For Now
    Milledgeville, GA
    2005 TRD OffRoad SR5 4x4 Short Bed Debadged
    20% tint, Debadged, Pioneer AVIC-Z110BT, Infinity component door speakers, MagLite mod
    Can you fully align the truck with the eibachs without getting UCA's?
  4. Nov 2, 2009 at 3:29 PM
    Dashe
    Dashe Well-Known Member
    David
    Charleston
    Black Double Cab SR5 4x4
    debadged, Grillcraft grille with FJ emblem, KC SlimLite Driving Lights behind grille, Bilstein 5100's, Eibach 1.6" lift springs, add-a-leaf, Pro Comp 7089 wheels, BFGoodrich A/T 285/75/16, Dynomax Super Turbo muffler, CB with Wilson Flex antenna
    nope. you really need to change out the stock UCA's if you're going to lift the front end. i drove for a while without doing this, because i couldn't afford them. they cant align it properly, and consequently the caster will be off, causing the truck to "wander" down the road. bottom line, get some aftermarket UCA's.
  5. Nov 2, 2009 at 3:38 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    are you reffering to the leveling springs or the 3" lift springs?
  6. Nov 2, 2009 at 4:59 PM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Not so. I have Eibach's w/5100's set at .85" and they were able to keep my alignment within spec.
    Truck tracks perfectly at low and high speed, and does not wander at all, under braking and acceleration.
    And ya- you will definately need an alignment after you remove the front springs/shocks.
  7. Nov 2, 2009 at 5:04 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    If your a lil tight on money "Light Racing" makes a solid UCA from what i've heard...otherwise get some Total Chaos UCAs. Those seem to be the best and alot of guys on here use em :)
  8. Nov 2, 2009 at 5:05 PM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Only if you go above 2" in lift. I just put my 5100 on at 1.75" and after the 2nd alignment I'm within specs.
  9. Nov 2, 2009 at 5:05 PM
    ColtsTRD
    Scott
    AZ
    x2
  10. Nov 2, 2009 at 5:13 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    1.6" lift.
  11. Nov 2, 2009 at 5:18 PM
    Masada
    Taylor
    Laveen, AZ
    Yes you will need to get it aligned, any time you lift the front end you need to adjust the alignment.
  12. Nov 2, 2009 at 5:40 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Yes. Just get it aligned and your good to go.
  13. Nov 2, 2009 at 9:46 PM
    canuck_tacoma
    canuck_tacoma Well-Known Member
    BC, Canada
    SR5 4X4 Tacoma Access Cab
    1.5" Eibach Front Coil Lift, Rear TSB, 265/75/16 BFG A/T's
    You will have no problems getting the truck alignment with these springs. You don't need to worry about a diff drop as well. That's why I went with them.
  14. Nov 3, 2009 at 8:10 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    anytime you lift you align from what iv heard, and with the eibach springs only giving 1.6" lift you dont need new ucas
  15. Nov 3, 2009 at 8:17 AM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Cool. Thanks. I'll be picking those eibachs up.
  16. Nov 3, 2009 at 8:37 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Any time suspension geometry is changed, your alignment will be out of spec and you'll have to get it re-alligned.
  17. Nov 3, 2009 at 9:06 AM
    311offroad
    Milledgeville, GA
    If I get these springs it will be my 3rd vehicle Ive bought springs from eibach for. I wander if I can some kind of discount or VIP customer service haha
