Do I drop my ball and how far?
Discussion in 'Towing' started by 07SpeedwaySport, Jan 12, 2011.
  1. Jan 12, 2011 at 12:39 PM
    07SpeedwaySport
    07SpeedwaySport [OP] Senior MoFo'ing Member
    Fairfax, VA
    06 DCSB TRD OR--now silver
    tint.
    Hey,
    I frequently use my trusty master tow dolly to pull around old cars and was wondering if I need a receiver that drops the ball height any?
    I used it with my old 98 pathfinder at stock height and didn't need any drop, towed wonderfully.
    I now have an 05 and 07 automatic DC Sport(s) with factory hitches on each truck.
    I haven't towed with either yet since I got them both only 3 weeks ago but they seem to be higher at stock height than the Pathfinder.
    Advise? Experience with dollys and Tacos?
    Thanks in advance.
  2. Jan 14, 2011 at 5:52 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    There is a reduction in capacity for each inch of drop or rise but I do not remember the exact ratio. If your load is sifnificantly less than the rated capacity of the hitch and truck I wouldn't worry about it. If it is close to the ratings I would not drop it much if at all.
  3. Jan 14, 2011 at 6:20 AM
    BCTacoma2010
    BCTacoma2010 Michigan Member
    Jay
    Southwest Michigan
    2010 TRD Sport Access Cab
    Nothing to see here, moving along...
  4. Jan 14, 2011 at 7:28 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    What drops in capacity, the truck's rated capacity, the receiver or the hitch mount? Never heard that before so now I'm curious.
    OP, you should get the correct rise/drop for what you intend to tow. It will make a huge difference in how well the whole set-up feels when going down the road. There's a towing bible in one of these threads that I'm sure explains the reasoning behind it.
  5. Jan 14, 2011 at 7:34 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Go deep for the win...
    Keep it the trailer tounge level
  6. Jan 14, 2011 at 11:19 AM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Well its pretty easy. How does the trailer sit when it is hooked up? Is the front end way up in the air? Then you need a drop
  7. Jan 14, 2011 at 11:36 AM
    Grande
    Grande Well-Known Member
    Victorville, CA
    Thomas, The little truck that could
    Painted badges. Bedlined grille, wheels and lower valence. Billies 5100 @.85 up front. Dodger Jack Ball Mod. Custom trail damaged rear bumper (for the time being). Lil LED light bar on grill. Hard-wired Radar Det. Custom Projector fog lights, Anytime Fog Mod, HIDS, White LED accent lighting on a Single post double toggle swicht, so they light up wit my door/dome light, or always on, or never on. LED map and dome lights.
    mine dropped many years ago, lol
  8. Jan 14, 2011 at 11:41 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
  9. Jan 14, 2011 at 12:40 PM
    arrowthrower
    arrowthrower Well-Known Member
    Logan
    Henderson, KY
    2011 DC Tacoma TRD
    This is way to easy to comment on. I always ask this question before I hit a mud whole. Is it balls deep??
  10. Jan 14, 2011 at 2:11 PM
    Cr250jumper
    The moon
    50 shades of tan©
    *Depends on how hot the girl is
  11. Jan 14, 2011 at 2:29 PM
    07SpeedwaySport
    Fairfax, VA
    tint.
    I figured I would get your attention with that one...
    Thanks, this is pretty helpful. The problem is that it is a tow dolly and I can't really tell what the "coupler height" is since it kind of pivots to where ever you want it (not sitting on two axles, just one)
    Time to hit up Google for the correct "coupler height" for a Master Tow dolly....
    my old set ups...
  12. Jan 17, 2011 at 11:07 AM
    JDCPA
    Jim
    SW FL
    The rating for the entire rig drops. THe truck rating is established with the trailer coupler at the heighth of the receiver.
  13. Jan 20, 2011 at 2:27 PM
    VancityCK
    VancityCK Well-Known Member
    Vancouver
    09 Magnetic AC TRD Offroad
    That's bullshit. Show me something that says a drop hitch reduces the capacity of a receiver. You won't find it on any manufacturers website, that's for damn sure. A drop hitch doesn't change the forces on a hitch in any way, so how would it affect the load capacity? An extender does, but a drop is not the same as a hitch extension. A hitch extension increases the leverage on a receiver and affects its capacity, but a drop just changes where it is being hooked up. There is no change in the forces being applied to the receiver, therefore no change in capacity.
  14. Jan 20, 2011 at 2:36 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    X2 on this, the ball mount is rated for what ever capacity it is rated for regardless of its rise or drop. It is hitch extenders that reduce total hitch capacity and the extender will/should have the reduction rate on it.
    Load 'er up and drag it down the road:D
  15. Jan 20, 2011 at 2:52 PM
    psmcn
    Paul
    Rockville Md
    I have two hitch set ups. One is the WD for my RV the other is an adjustable height ball mount that is rated at 5000# and I put the Reece quick Interchangeable Hitch Balls on it which covers all three sizes. Works well for me as long as I'm under 5000#
    Click on blue links
    Hope this helps
    Paul
  16. Jan 20, 2011 at 5:33 PM
    sam_i02
    sam_i02 Well-Known Member
    Samir
    Kanata, Ontario
    05 PreRunner AccessCab
    BHLM, Satoshi grill, D-rings, Relentless Fab recovery shackle, DRL, Firestone RideRite airbags, WO seatcovers, added temp gauge, custom interior lights.
    Go as low as you can without it being painful. Its a fine line between pleasure and pain, so keep a pre-determined threshold in mind and try not to exceed it in the heat of the moment.
  17. Jan 20, 2011 at 5:36 PM
    focotacoma
    focotacoma Well-Known Member
    Fort Collins
    07 Speedway Blue 4x4 TRD off-road
    Im getting there......
    thank you!!!:D
    and to answer the ops question
    the deeped the better just watch for inherent hazards
  18. Jan 21, 2011 at 10:20 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    My left one drops lower than the right.
    With a tow dolly I don't think you have to be too concerned with it, since the tongue weight is minimal. I've got 3 different setups for mine depending on what I'm towing. I like for my trailer to be level. My boat gets a 2" raised ball. Car trailer gets a 2" drop, and the travel trailer is straight.
  19. Jan 21, 2011 at 10:34 AM
    Joben7726
    Joben7726 wes mantooth ™
    Joben
    Western PA/Va Beach
    Trail limo
    more than list-able
    one time i tried to drop them in her ass...
    =EPIC-FAIL.
  20. Jan 30, 2011 at 6:56 PM
    07SpeedwaySport
    Fairfax, VA
    tint.
    Thanks all. I didn't do the research like I meant to do, but took a trip with it today as-is anyways...I went from DC to VaBeach, like 170 miles with the dolly unloaded and came back with a Corolla loaded about 120 miles and then 50 more unloaded to get home...
    -Much quieter than with my old Pathfinder due to a better receiver on this Tacoma maybe?
    -Much easier to pull than with the crappy 3.3L Nissan.
    ----Drove smoooooth! Hardly knew it was there and I was pushing 80mph most of the time...(lets not talk gas mileage...wonk wonk wonk)
    SO, now to a new question...I just got this truck and the leaf spring TSB has not been done(still 3 springs)...I plan on towing with it at least 3-4 times a month, generally not longer than 50 miles...and probably nothing heavier than a Passat or a Camry...
    How urgent is the leaf TSB?
    How does it affect towing?
    I don't wanna do it cause I am cheap...and it causes harsher ride when unloaded...and so forth.
