Do I have limited slip diff and what diff fluid
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DANGERMONEY, Jul 3, 2018.
  1. Jul 3, 2018 at 3:40 PM
    DANGERMONEY
    DANGERMONEY [OP] Well-Known Member
    Called Toyota Corporation and they looked up my Taco....they said I have automatic LSD.
    I have a 2014 OR with manual rear locker and atac
    I want to figure out what weight diff fluids I need and if I need lsd additive for rear.
    I've read many posts here and videos but some say you only need it for the sport and not the off road.
    Edit....what weight for front. Rear and transfer?
    Some posts state this then a poster comes behind another and says...nah. I only use this and that's not necessary
    Advice is greatly appreciated. Thx...
  2. Jul 3, 2018 at 3:43 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I used Mobil1 75-90. Front, rear and transfer case. No additive in a 2014 Sport.
    henryp likes this.
  3. Jul 3, 2018 at 3:44 PM
    Pigpen
    Dan
    Northwest Montana
    MolonLabeTaco likes this.
  4. Jul 3, 2018 at 3:58 PM
    DANGERMONEY
    Thanks so much!
