Do I need a brake proportion valve? Whats it for?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Madams, Apr 30, 2011.
  1. Apr 30, 2011 at 12:03 PM
    Madams
    Madams [OP] Well-Known Member
    South Carolina
    They call it barney
    For the rear of my taco Im getting it lifted 2" with toytec aal's. Do I need a brake proportioning valve bracket? I have looked at the 2.5 inch toytec spacer lift and it included that brake proportioning valve thing.(not going with spacer lift) just wanted to know do I need that brake proportioning valve bracket? Dont want to get something I dont even need cause it will be wasting money.
    (Im getting 5100's and eibach springs and 2" aal in the rear.)
  2. Apr 30, 2011 at 12:36 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    It helps even the brake load for front and rear, with the loft in the back, they front brakes are going to be getting used more than the rear without the bracket. I'd look at Beefed Tacos BPV bracket, it's made of better material, and it's about the same price as the flimsy Toytec one.
  3. Apr 30, 2011 at 1:35 PM
    Madams
    South Carolina
    They call it barney
    thanks
  4. Apr 14, 2012 at 4:52 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    But why...?
    I get it, that without the bracket a lifted truck with shift more braking to the front than stock. But what is the functional reasoning? If the truck were stock and the bed were unloaded the braking would be balanced, but why proportion the braking to the load in the bed? when loaded the distance from the frame to the rear axle housing is shorter activation the proportioning valve. So in stock situation and there was a heavy load in the bed, it would seem that the truck would proportion braking away from the front and move it to the rear.
    Whats the advantage to this as the front brakes seem stronger?
  5. Apr 14, 2012 at 5:43 AM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    The rear proportioning valve in my opinion is a bit of over engineering, useful but not needed. However your Tacoma was designed to use it so you should retain it and ensure that it is working properly.
  6. Apr 14, 2012 at 6:04 AM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    the brakes are usually divide between 60-70% fronts and the rest to the rear,(in general) Helps you STOP as apposed to sliding. Also the load in the bed has to be calulated to get the best (shortest) stopping distance.
    Jump on a mountain bike and slam on the rear brake while on asphalt.. you slide. now lock up the front... it Stops. the proportioning valve makes it all work together.
  7. Apr 14, 2012 at 6:26 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    So I might be slow on this, but when the bed/frame is lower to the axle as when weighted, why does it take stopping power from the front brakes?
    I did the bracket install, but am just curious as to why it was engineered this way.
  8. Apr 14, 2012 at 6:39 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I'll try to explain this ....so please pardon.
    Toyota put a mechanical sensing device under the truck bed to sense the load - so the brakes could adjust accordingly for optimum braking performance when you are carrying a heavy load.
    If you look underneath the truck, its a long steal (round bar) that goes from the axle to the bed (where the sensor is).
    You LIFT the rear of the truck, this changes the input at the sensor assuming you have a *LIGHTER THAN STOCK* load in the bed.
    The Brake proportioning bracket - should be the same height as your lift. This puts the sensor back to ORIGINAL position of the STOCK LOAD. So, if & when you ever put a load in the truck, the sensor can act as it would normally and give you the braking performance that Toyota engineered.
    2nd gen trucks don't have one...so I'm not sure how that works....
  9. Apr 14, 2012 at 6:51 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Couldn't of said it better myself :cool:
    a lot of guys with auto trans will burn up the brakes faster ( manual trans is a little less because of engine braking) after installing a lift because the rears are not being used as they should. I ran with out a relocate bracket for the longest time after installing mine the stopping power way noticeably better. You can always make one for a few bucks it doesn't take much.
    I also offer 2 different sizes my design is fully adjustable so if you lift higher or don't like the stopping power you can always move it up.
    http://www.tacomaworld.com/forum/bay-area-metal-fabrication/184065-b-m-f-bpv-relocate-bracket.html
  10. Apr 14, 2012 at 7:03 AM
    abbller
    abbller Member
    It helps even the brake load for front and rear.[​IMG]
  11. Apr 14, 2012 at 7:04 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Truth. Warped my front brake rotors after my lift.
  12. Apr 14, 2012 at 7:12 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    So a weighted bed increases the brake proportioning towards the rear brakes. Ok, it still seams counter intuitive as the front brakes have more stopping power. Or does the truck really stop better with more rear brakes with the bed loaded?
  13. Apr 14, 2012 at 7:20 AM
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    When the bed is lightest, the rear brake doesn't have as much effect on stopping power. As you add weight, the rear brake has more effect. The total stopping power is improved when you use both front and rear brakes.
  14. Apr 14, 2012 at 7:23 AM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    the front brakes have more stopping power because when you stop all the weight is shifted forward to the front wheels, and they won't skid as easy as the rears. The back wheels will lock up when they have no weight on them. When you load up the bed, you have weight on them now, so you can give the brakes
    "more" power to stop the truck better without skidding the rear wheels.
  15. Apr 14, 2012 at 7:34 AM
    Janster
    Jandy
    Lancaster, PA
    Anytime you add weight - you need more stopping power. Ask anyone who tows....more weight = more momentum = longer stopping distance. The front brakes will always have more stopping power. It's the rear brakes that will get MORE and be more effective.
    Aside from all that - there's a weight distribution thing that also plays a role in the engineering of the braking. Put a lot of weight in the bed and the front end of the truck will pitch upward. This 'decreases' steering effectiveness and can also decrease braking effectiveness simply because the weight isn't there. So again, the brake proportioning is designed / engineered for optimum braking performance based on all those factors that have already been listed.
  16. Apr 14, 2012 at 7:42 AM
    186000mps
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Now makes perfect sense !
    Thank you all !
  17. Apr 14, 2012 at 10:15 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    straightawaykid likes this.
  18. May 26, 2012 at 4:26 AM
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    Bringing up an older post here...
    So I installed Jerry's bracket, and I am looking into doing my rear brakes, but, how do I know my BPV is actually functioning the way it should?
    I have done a few other mods to my truck, things that take WAY more time then they should because of rust and corrosion on a truck that has been in Chicago the entire time I have owned it.
    Am I over-assuming that my BPV would be affected in the same way that most other under carriage parts are on my truck?
  19. May 26, 2012 at 10:50 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    A proportioning valve is used whenever a vehicle has disc brakes front and drum brakes rear. Disc brakes require "static pressure" to keep the pads close to the rotors, and the drums use wheel cylinders and shoes. The valve makes it possible for two brake types to work together. If you were to use 4 wheel disc brakes you wouldn't need the proportioning valve.
  20. May 5, 2020 at 12:57 PM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    Bumping this 8 year old thread to help others understand about this device. Janster explains the importance of it exceptionally well. (Read quoted info above.)
