do i need a relay?
Discussion in '2nd Gen. Builds (2005-2015)' started by AJ4X4, Jul 14, 2012.
  1. Jul 14, 2012 at 6:23 PM
    AJ4X4
    AJ4X4 [OP] Well-Known Member
    White 2010 TRD Off Road Double Cab
    I just recently got my 280c 150psi hi flow air system for a horn i built. Do i need to wire a relay in or not? Thanks guys
  2. Jul 14, 2012 at 8:07 PM
    AJ4X4
    Bump. Quick response would be very helpful.
  3. Jul 14, 2012 at 8:09 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
  4. Jul 14, 2012 at 8:37 PM
    AJ4X4
    Thank you. Do you know of a diagram of how to do it?
  5. Jul 14, 2012 at 8:39 PM
    AJ4X4
    I also have a switch that is rated at 3A 250v switch. Will that work with my compressor
  6. Jul 14, 2012 at 8:53 PM
    2000GTacoma
    Snow Hill NC
    a relay is just a remotely operated switch. it takes the load so you do not have to run heavy wires in and out of the truck. 86 and 85 are used to trigger the relay. positive and ground are run to 85 and 86. postive to one ground to the other does not matter which is which. 30 is input power. wire from your battery. 87 is output from relays. the pins 85 and 86 connect pins 30 and 87
  7. Jul 14, 2012 at 9:23 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    this^^^^^^^^^
  8. Jul 14, 2012 at 9:30 PM
    AJ4X4
    So by this your saying that switch will work?
  9. Jul 14, 2012 at 10:15 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    Yes
