Do I need Fender Flare Trim
Discussion in '1st Gen. Tacomas (1995-2004)' started by DUCKSHOT, Jun 6, 2013.
  1. Jun 6, 2013 at 2:00 PM
    DUCKSHOT
    DUCKSHOT [OP] Well-Known Member
    TX
    01' Tacoma PreRunner
    I'm about to roll on bedliner my fender flares and the rubber gasket material that goes beween the flare and the truck is coming off. Could I just bedliner the flare and just install it? Is it there to keep the flare from rattling? I figure with bedliner material on the truck and the flare it should keep it from rattling.
  2. Jun 6, 2013 at 2:52 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Those gaskets are only there to give it a finished look. They are held on with two-way tape to both the flare and body. The flare might pull away at the top slightly, but of you don't care about a 1/8" gap I'd say leave it. They are roughly $25 a piece from the Toy maker.
  3. Jun 6, 2013 at 5:53 PM
    Seventh
    Seventh Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    When I had stock flares on, that trim was long gone on my '01 and they made no noise at all. I wouldn't worry about it.
  4. Jun 7, 2013 at 10:45 AM
    DUCKSHOT
    TX
    Sweeeeeet, gunna order my bedliner material then. Thanks!!
