Do I need to change leaf spring?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caffeine89, Mar 19, 2021.
  1. Mar 19, 2021 at 7:04 PM
    Caffeine89
    Caffeine89 [OP] Member
    Watson
    2019 Black tacoma trd off road
    Nitto ridge grappler and fuel rims
    So I broke my stock bilstiens so I thought that now is a good time to upgrade. I'm going to get the fox 2.0 reservoirs which come with a 2-3 inch lift (in the back). So if I get this shock will I need to get a new leaf spring due to the increased lift?
  2. Mar 19, 2021 at 7:22 PM
    Jojee117
    Jojee117 Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    The leaf springs are what provide the lift. If you were to get the 985-24-117 shocks (for 2-3" of lift) you wouldn't change your ride height, but you would get 1.5" more inches of possible droop and you would move the compressed length down 1" compared to the 0-1.5" lift shocks. This means without changing the leafs you would lose 1" of up travel, you might get more droop (probably limited by the leafs anyway), and you would want to put a spacer on your bumpstop so you don't bottom out the shock.
  3. Mar 19, 2021 at 7:30 PM
    Caffeine89
    Watson
    So then if I got 985-24-116 (which has no lift) the ride height would stay the same right? The only difference being the suspension feel. Thanks for your help
  4. Mar 19, 2021 at 7:33 PM
    Jojee117
    Joe
    MT
    Springs are what effect ride height, shocks only control the cushioning, so yes. If you don't plan on adding blocks, and aal, or new leafs, I'd get the 985-24-116s.
    Skydvrr likes this.
  5. Mar 19, 2021 at 7:38 PM
    Caffeine89
    Watson
    So if I did want to get a lift in the rear, what method of lift would be the best?
  6. Mar 19, 2021 at 7:42 PM
    Bigpat_ca
    Bigpat_ca Well-Known Member
    Sacramento, CA
    2014 Spruce Mica TRD off road DCSB
    Depends on your budget, add a leaf is an option but is really just a bandaid a whole new spring pack would be the best option, Dakar’s are popular and some what budget friendly but deavers IMO are the best way to go.
  7. Mar 19, 2021 at 7:42 PM
    Jojee117
    Joe
    MT
    The best would be a new leaf pack, but I've seen a lot of people get great results from a 3 leaf AAL. I don't have any personal experience with them, so you might want to search some common AALs for reviews on here or wait for others to chime in. I know the Icon 3 leaf aal has a good reputation around here though. It really depends on what you use your truck for too.
  8. Mar 19, 2021 at 7:42 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  9. Mar 19, 2021 at 7:48 PM
    Caffeine89
    Watson
    I do a lot of high speed off roading so I need something that won't break as easily and I also don't carry any load in the back
  10. Mar 19, 2021 at 7:50 PM
    Jojee117
    Joe
    MT
    Then I would think you definitely want a nice leaf pack. You should start doing some research on the other's suggested packs.
    Caffeine89[OP] likes this.
