Do I Need To Change The Spare To A Larger Size?
Discussion in 'Wheels & Tires' started by Bogard, Aug 19, 2010.
  1. Aug 19, 2010 at 7:53 AM
    Bogard
    Bogard [OP] Well-Known Member
    Bill
    Pennsylvania, USA
    I recently put a set of FJ rims with 265 70 17's on my DC. The current spare tire size is 245 75 16. The new tires are larger. Is it necessary up-size the spare to match or is the current spare size ok?
  2. Aug 19, 2010 at 8:03 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    With 1" difference - I wouldn't run it. The two wheels will have a different rolling distance and that could create problems in the diff even if its an OPEN diff. Personally, never tried it myself and I wouldn't dare try it (just in case).
    Call around to local shops in your area - ask for a USED 265/70/17 tire. Even if they have ones that are 'out of inspection' but have plenty of tread left are good enough to use as a spare and would be much cheaper than buying a new one.
  3. Aug 19, 2010 at 8:13 AM
    Bogard
    Bill
    Pennsylvania, USA
    I was thinking the same however my stock spare rim is 16"...so how about 265 75 16?
  4. Aug 19, 2010 at 8:35 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    that will work . I have same set up as ur , I took 1 wheel off and put spare tire on then measure same level .
  5. Aug 19, 2010 at 8:53 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Using dissimilar rims, even if the tire size makes up for the size difference, will cause handling problems. The smaller rim tire will not sit the same as the others.
    It'll probably get you home, but i wouldn't risk it. Match all the rims and tires. Cheaping out can cost you more than you'd like to pay.
