Do I need to get new shocks???
Discussion in 'Suspension' started by Sheepdog, Oct 28, 2009.
  1. Oct 28, 2009 at 6:22 PM
    Sheepdog
    Sheepdog [OP] Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    So here's my situation... I want to lift my truck without having to go buy one of those expensive IFS lift kits. I already have 3" spacers in the front ontop of the coils and it's my understanding that i'm about maxed out for the stock IFS with the 3s. I was thinking about putting on a 2-3" body lift kit and then do a 4" lift in the back. So I will have 5-6" total lift in the front and 6-7" in the rear, so I will sit a little head low I think. Now here's my question: Do I need to replace my stock shocks, if so, what shocks do you guys recomend? Size? (Remember, I'm on a limited budget)
    Thank you,
    Gary
  2. Oct 28, 2009 at 6:29 PM
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    Don't do it, just stay with what lift you have.
  3. Oct 28, 2009 at 6:39 PM
    Sheepdog
    Gary
    San Diego, CA
    Well Im sitting head high right now and I put a roll bar in the bed so now it really saggs. Are there cons to putting that kinda lift on?
  4. Oct 28, 2009 at 6:41 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    body lifts are week and look awfull.
    you will gain nothing from doing that. if it were me I would replace with some good shocks and remove the front swaybar, you will get alot better offroad performance.
  5. Oct 28, 2009 at 6:42 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    if you dont have any lift in the rear you can do the aal and level it back out.
  6. Oct 28, 2009 at 6:44 PM
    Sheepdog
    Gary
    San Diego, CA
    Ok. So you are saying that if I were to lift it more, to stay with the suspention lifts?
    And not to argue, buy why would I remove the sway bar? Isn't it there for a reason? What would the advantage be in removing it?
  7. Oct 28, 2009 at 6:44 PM
    Sheepdog
    Gary
    San Diego, CA
    Whats an "aal"?
  8. Oct 28, 2009 at 6:46 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    yes, suspensiop lifts are the way to go, function over form.
    there are lots of trucks on here that remove their swaybars to get better wheel travel/articulation.
  9. Oct 28, 2009 at 6:47 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    AAL= add a leaf. its an extra leaf spring that you add to get a few extra inches in the rear of the truck. there are around 80 bucks from toytec
  10. Oct 28, 2009 at 6:49 PM
    Sheepdog
    Gary
    San Diego, CA
    Okay. Looks like I'm gonna have to go with one of those expensive IFS lift kits then?
    Will removing the sway bar effect the performance in a negative way on the vehicle overall? On the street and just regular daily driving?
  11. Oct 28, 2009 at 6:50 PM
    Sheepdog
    Gary
    San Diego, CA
    Doesn't the suspention get stiffer and the ride less comfortable with the extra leaf?
  12. Oct 28, 2009 at 6:51 PM
    awymore997
    awymore997 Quitting is for Quitters
    Andrew
    Charlotte, NC
    08 Access Cab TRD OFRD 6 speed
    How much do you plan of taking your truck off road?
    The problem with a big IFS lift is that they are what is called a Drop Bracket setup, which lowers the mounting points of your lower control arms, so in the end you really dont gain much ground clerance, just what is provided by bigger tires.
    Body lifts do work, but you will end up with a gap between your body and frame that looks really bad, and again you dont gain any performance, just the ability to put bigger tires on.
    The swaybar is personal preferance, you will get better off road performance, and you dont lose very much streetability. I have had mine off for over a year with no ill effects. Another option is sway bar disconnets, I have a buddy that is going to start making some for tacomas as soon as we get a few details hammered out and find some trucks to test fit.
  13. Oct 28, 2009 at 6:52 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Your only 16 I say keep it on. No offense but only experienced drivers should take it off. It creates body roll. So less control if you ever had to swerve hard. No negative effects though besides that.
    Just save for a nice lift.
  14. Oct 28, 2009 at 6:52 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    you dont have to spend a fourtune to lift your truck.
    check out
    wheelersoffroad
    toytec
    allprooffroad
    downsouthmotorsports
    all good companys
    toytec has coilovers for about 800 i think.
    offroad it will all be gains. on road you will notice a little bit more body roll. on mine its not really noticeable since I added new coilovers
  15. Oct 28, 2009 at 6:54 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    good call, i didnt see that he was a younger driver.
    yes, forget I mentioned that, leave it on.
  16. Oct 28, 2009 at 6:56 PM
    Sheepdog
    Gary
    San Diego, CA
    Great input Andrew. Thanks.
    I only take it offroad a couple times a week and when I do, I don't get too radical because this is my daily driver and I cant really afford to replace it.
    Is there anyway to lift IFS without lowering those contoll arm mounts?
  17. Oct 28, 2009 at 6:58 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    x2 :thumbsup:
  18. Oct 28, 2009 at 6:59 PM
    Sheepdog
    Gary
    San Diego, CA
    Good point Keller. I'm still a new driver, thats true. I don't want to do any modifications that would effect the controll of the vehicle in day-to-day driving.
    No offence taken, you have a great point.
  19. Oct 28, 2009 at 7:03 PM
    awymore997
    Andrew
    Charlotte, NC
    Yes, the best bet is either Bilstein 5100's or Aftermarket coilovers, depending on your budget. EDIT: These will not give you any more than the 3" you already have, but will offer a better ride and better performance. Also you may want to look into a set of aftermarket UCA's, they will help with your alignment and offer a little bit more travel without the fear of tearing uo ball joints.
    As others have stated, check out Toytec and Downsouth Motorsports, they will have everything you need and contribute a lot to these forums.
    And, if you need help installing the lift after you get it, Im sure there is someone in your area on here that would be more than happy to help.
  20. Oct 28, 2009 at 8:04 PM
    Sheepdog
    Gary
    San Diego, CA
    Thanks for all your guys' input. I greatly appreciate it.
