Do I need to re-gear?
Discussion in 'Wheels & Tires' started by lilcez3, Jan 9, 2019.
Do i need to re-gear based on the info provided?
  1. Yes, definitely
    33.3%
  2. Don't need to
    66.7%
  1. Jan 9, 2019 at 9:45 PM
    lilcez3
    lilcez3 [OP] Well-Known Member
    None yet
    Happy New Year Fellas.
    Hopefully someone can help with my following dilemma. I've read a lot throughout the forum regarding differentials and re-gearing. I plan to get a lift this year, new tires, and wheels. If I'm lucky, I want to get the new 17" volk wheels from ShowStoppersOffroad that come out this summer. Apparently they will weigh 18 lbs. My tires would be Falken 285/70/r17 which weigh 50 Lbs.
    My wheel / tire set up would be ~68 Lbs. I have a 2nd gen Auto DCSB with 3.73 gear ratio. My question is, would I need to re-gear to match the new tire rotation? I occasionally go on fire trails on weekends & do a few trips to Mammoth, but I mainly use the truck to commute to work.
    Why do people tend to regear? To get power back due to heavy tires/wheels? Or simply to match stock specs with tire rotation? Or Both? My Wheel / Tire set up would be super light compared to other people.
    What is the experience for those of you that have 33's but have not regeared?
    https://www.amazon.com/Falken-Wildpeak-AT3W-Terrain-Radial/dp/B01C53CMCS
    Thanks in advance
  2. Jan 10, 2019 at 6:42 AM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    Need to? No. I’d do the lift and new tires first, see how it drives/feels and then evaluate if you personally think you need to spend 1500-2000 on the regear. I’m guessing you won’t, but everyone has differing opinions on what is an acceptable loss of power/fuel economy.
    lilcez3 [OP] likes this.
  3. Jan 10, 2019 at 7:20 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2014 Tacoma DCSB..Pyrite Mica...6 sp MT
  4. Jan 10, 2019 at 7:24 AM
    honda50r
    honda50r Not a Mallcrawler
    East Tennessee
    2nd Gen Tacoma
    Not Stock
    I'm not sure what you are trying to accomplish here. Install your parts and then if you feel you need to regear then do so.
  5. Jan 10, 2019 at 7:31 AM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I've got 33's. I didn't regear. I really don't think you'll need to.
  6. Jan 10, 2019 at 6:54 PM
    lilcez3
    None yet
    What's your wheel/tire set up? I think your 2017 might have a different gear ratio than mine (If that means anything)
  7. Jan 10, 2019 at 9:33 PM
    Thunder Fist
    David
    Birmingham, AL
    Like, so many.
    285/70/17s on 0 offset wheels.
