Do I need to regear with a 3inch lift and 33 inch tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anasseef, May 27, 2011.
  1. May 27, 2011 at 7:41 PM
    anasseef
    anasseef [OP] Active Member
    Chandler AZ
    Tacoma TRD Off Road
    STAGE 1 COILOVER SYSTEM
    I have been reading about the option to regear when you add larger tires. Is there a minimum set that you should always regear at above 3 inches, and 35 inch tires or should I just regear with what I am doing?
  2. May 27, 2011 at 7:43 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    your fine with stock gears on 33's, even 35's. But IF you do upgrade bigger then 33's i would regear. Im running a 3 in with 33's and i do just fine.
  3. May 27, 2011 at 7:43 PM
    Tlook
    Tlook Well-Known Member
    i didnt but i get 15mpg now haha
