Do I need to replace my Differential fluid?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Track, May 31, 2018.
  1. May 31, 2018 at 3:13 PM
    Track
    Track [OP] Well-Known Member
    Tuck
    Florida
    2017 TRD offroad
    MobTown bed racks MobTown sliders and skid ARB onboard air
    I spent to better part of Sunday on the trails in Ocala National Forest. Quite a bit of water, some up and over the wheels. I don’t have a breather yet so do I need to drain and replace the diff fluid. Transmission too? If it makes a difference it was the first time I had water crossings.
  2. May 31, 2018 at 3:27 PM
    phsycle
    phsycle Well-Known Member
    CA
    Most likely, you are fine. Vent valve can take on some light water crossings. It does prevent water from getting in while letting the diff breathe.
    But if you want to be sure, there is really no other way than to drain and fill.
    Track[OP] likes this.
  3. May 31, 2018 at 4:28 PM
    Pax11B
    Pax11B Well-Known Member
    2017 Quicksand Tacoma TRD OR AC
    https://www.tacomaworld.com/threads/pax11b-quicksand-build.491885/
    You could open up the fill plug and see if there is any water. It'd be a milky color if water got in. How many miles are on it?
    I just changed my diff fluid at 15k and aside from the metal shavings on the magnet the fluid was pretty clear for 15k but was wanting to get all that old stuff out anyway. And I hadn't done the breather mod at the time I did water crossings so I was on the "what if" side.
    It's super easy to change compared to other vehicles
    OnHartung'sRoad likes this.
  4. Jun 1, 2018 at 12:21 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Yeah super easy. My front diff oil was real dark when I changed it at 15K and I don't wheel all that often.
    Use synthetic to replace.
    While yer down there checking fluid, its only one more plug. Just plan on changing it out and save you the trouble crawling around 3x.
    Be sure to remove the fill plug 1st. very important. 1st time I changed mine the drain plug I needed to use a breaker bar to get it open on 1 of em. Need a few crush washers and some special washers if you're doing all of it. There's a kit on azon.
    https://www.amazon.com/gp/product/B017V4BAXI/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    crush washers needed too handy to have extras.
    https://www.amazon.com/gp/product/B01FUVMDBC/ref=oh_aui_detailpage_o00_s03?ie=UTF8&psc=1
    I just ordered 2 sets of the diff/transfer and a 10 pack of the crush washers.
    Not sure about the diff/transfer kit - there's not enough crush washers there so you need some extra but the copper and flat washers you need them. Some folks probably dont replace them. Couple of bucks and no worries. done
  5. Jun 1, 2018 at 12:43 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Remember, dif breather 1st, then try it out in the water.
    But do the oil test first - water will be at the bottom of the diff if you let it sit for a day.
  6. Jun 1, 2018 at 3:04 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you have over 5k miles on the original oil change it regardless.... that break in oil is gonna look nasty and have all sorts of metal shavings in it.
    Also its not the OEM breather that will let in water (as its a one way valve that only lets pressure out) its the fact that it does only let pressure out which means a vacuum can get created easily when you dunk a hot axle in cold water and water will get sucked in the pinion and axle seals rather easily.
  7. Jun 1, 2018 at 3:50 PM
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
  8. Jun 8, 2018 at 4:55 AM
    nhparrot
    nhparrot Well-Known Member
    Glenn
    SWFL
    2020 Silver SR5 V6 2WD DCSB , aka Lolita
    First oil change at 1k and diffs and transfer case at 10k for me
    Jcyr likes this.
  9. Jun 8, 2018 at 5:02 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    I like thisplan
