Do I need to replace my transmission filter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by taco2010trd, Jun 20, 2017.
  1. Sep 4, 2020 at 7:07 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    7 ft/lbs for the strainer (filter)
  2. Sep 4, 2020 at 7:49 AM
    salvage 2011
    salvage 2011 Member
    danny
    2011 white tacoma trd
    thank you thank you , you little Devil :canada:
  3. Oct 2, 2020 at 6:25 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Is there anything special I need to do with the pan gasket like putting permatex gasket maker?
  4. Oct 2, 2020 at 6:30 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    I didn't, just torqued to spec and hasn't leaked a drop in months. So no.
  5. Oct 2, 2020 at 9:04 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    some of this helps keep it in place when you're putting it back on. that damn gaskets always come creased and fucked up from being packed in the box. this helps line it up and keep its shape on the pan
    Lucifer1 likes this.
  6. Dec 6, 2020 at 10:44 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Is this the part number for the AT trans filter? Part Number: 3533060030?
  7. Dec 7, 2020 at 12:35 PM
    Sailormilan2
    Sailormilan2 Member
    Dale
    2006 Tacoma TRD acces cab
    What I did was to install a Purolater P1320 inline transmission filter on the transmission cooler return line when I changed the fluid the first time.
    I changed the fluid at about 90k miles, and it was dark. Almost black. Still very dark red after drain and partial refill.
    After 30k miles(recommended filter change interval) the fluid was almost red again. Working on my second inline filter. In another 10k miles I’ll do another drain and refill, and change the filter again.
    Much easier to change the inline filter.
  8. Dec 7, 2020 at 8:51 PM
    Frez1812
    Frez1812 Well-Known Member
    2012 Tacoma 4.0
    Called my Toyota dealer today about a tranny service and this is what he said.
    What we have is a product made by BG products. It is a full synthetic transmission fluid flush. We add a cleaner, drive the truck and then run the flush machine and flush out the old fluid and add the new fluid and also a conditioning fluid. We charge $200 for that service, it takes around an hour to do.
    BG service anyone?
  9. Dec 7, 2020 at 9:19 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Just clean the screen.
  10. Dec 7, 2020 at 10:44 PM
    steelcity2
    Pittsburgh Pa
    No way!! :facepalm:
    A proper transmission service is to drop the pan change or clean the screen , clean the pan and magnets then fill up with transmission fluid.
  11. Mar 21, 2022 at 7:58 PM
    Taco15Bob
    Taco15Bob Member
    Bob
    2015 S5 4 door Prerunner
    None
    I replaced the Transmission filter over the weekend on my 2015 Prerunner 2w drive. I measured all the fluid I drained and drained from the filter when I took it out. Old fluid was 3 1/2 quarts. When I put the new fluid back I was very carefull bringing it up to temp. I have a Scanguage II that displays Transmission temp. It took 4 quarts of new fluid. So I have been running 1/2 quart low since I bought it new. Now transmission shifts smoother than it every has. Always could really notice the shift points, now shifts very smooth, better than ever. Also sometimes it would slip a little between 1st and 2nd, doesn't now. I have read about this. Some Taco's are low on fluid new. My son bought a 2018 Tacoma Prerunner 4w drive. Within a few 100 miles he installed a Scanguage II to measure transmission temp and we checked trans fluid by putting 1/2 quart in then draining it. We drained 1/2 quart out on level check so his transmission fluid level was ok. I wish I had checked my fluid level sooner, hope there was no damage to transmission.
    kbecerra, Doc Samson and steelcity2 like this.
  12. Mar 8, 2023 at 11:12 PM
    kbecerra
    kbecerra Well-Known Member
    2006 Red Tacoma Double Cab Long Bed PreRunner
    Eibach Pro-Truck Lift (Stage 1), Deaver AAL, JBA STD UCAs
    I have a 2006 Tacoma Prerunner DBLB with 166,070 miles. According to Carfax and the dealer that the previous owner had the maintenance done, the Transmission Flush/Fill was done.
    When it’s time to Flush/Fill should I also change the transmission filter and transmission pan gasket?
    Thanks been learning a lot here
  13. Mar 8, 2023 at 11:39 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I would recommend changing the filter when you do a full flush. If you're changing the fluid anyways, it's not that much more work to drop the pan to replace the filter (and the gasket).
    And when I say flush, I mean this: https://www.tacomaworld.com/threads/diy-full-flush-for-automatic-transmission.68462/
    kbecerra[QUOTED] likes this.
  14. Mar 8, 2023 at 11:58 PM
    kbecerra
    Awesome! That’s the link I have saved for the complete fluid flush and fill.
    Thanks again for your recommendation on the Transmission filter & gasket. I’ll now be doing that as well!
  15. Mar 9, 2023 at 12:17 PM
    #35
    kbecerra
    Forgot to ask since this is the first time I’ll be doing the Transmission Flush. Do you recommend the Genuine Toyota ATF (WS) or another brand.
    Thanks again
  16. Mar 9, 2023 at 12:21 PM
    #36
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If you do the flush correctly, No.
    Use MaxLife
    Correctly is important.
    Here is correctly
    Here is why I suggest going with a fluid other than WS.
    https://www.tacomaworld.com/threads...e-get-it-out-of-your-transmission-now.331521/
  17. Dec 10, 2023 at 6:30 PM
    #37
    Orlando roofer
    Orlando roofer '15 Prerunner i4 2.7 DC SB RWD AT
    Sean
    '15 Prerunner i4 2.7 DC SB Auto
    Hi,
    my 2nd gen 2015 2.7 double cab 4x2 auto has 247,000 miles as of this writing in December 2023.
    i drain transmission oil every 30,000 miles (because oil is cheap n transmission is not) ; it has original transmission and original transmission oil filter.
    i only use Toyota OE transmission oil.
    the transmission runs like brand new....!
    check out few videos of my tacoma maintenance.
    Savitara General & Roofing Contractors - YouTube
    if i do change the transmission oil filter - i would only go with Toyota OE !
    TacomaWorld has help me a lot keeping my tacoma healthy!
