do I need UCA's?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tmat, Sep 5, 2009.
  1. Sep 5, 2009 at 12:30 AM
    tmat
    tmat [OP] Well-Known Member
    Treavor
    Cypress, CA
    07 Regular Cab, PreRunner
    BHLM, de-badged, custom Manoukian flowmaster exhaust system, Bilstein 5100 front adjustable shocks set at 1.75", "smoked" foglights, Satoshi grille mod, 265/75r16 BFG T/A KO tires, AFE Pro Dry S air filter, solid rear window, Weathertech floor liners and painted grill surround
    I'm planning on getting the Camburg Allied Spindles...I heard somewhere that I wouldn't need new UCA's...well technically I don't NEED them, but would the alignment be off enough to where - let's say - Total Chaos UCA's would be necessary? Thanks guys.
  2. Sep 5, 2009 at 12:38 AM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    you will be fine with just spindles, but if u plan on getting coil overs then you will need them.
  3. Sep 5, 2009 at 1:13 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Correct. Thats whats nice about spindle lifts. They dont screw up your stock geometry
  4. Sep 5, 2009 at 10:01 AM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    pretty much anything above ~2" of coil lift you will need new UCAs to correct the alignment. if your running lift spindles and OEM shocks or coilovers set at below 2" your good to go w/ the OEM arms.
  5. Sep 12, 2009 at 1:03 AM
    StaticTaco
    StaticTaco Well-Known Member
    Mitch
    Oahu
    2011 SR5 4WD
    hey guys, thought i'd just continue this thread, im considering getting the tc lift spindles and was wondering if i can use it with my 5100s?
    at the moment im at 2.5" with the 5100s and tc ucas with a 1" block in the back. i was just wondering if i can set the 5100s at stock height and just put in the spindles and i'll have 3.5" of lift?
    its too bad that it seems i didn't have to get tc ucas, if i were just to go with the spindles to begin with. oh well... they do look cool under there :)
    thanks for info guys.
    EDIT: ok, so i just found this thread,
    http://www.tacomaworld.com/forum/suspension/45609-installed-camburg-spindles.html
    so from what i understand i can use the 5100s at any height and that'll just be added to the tc spindles 3.5" ? if it is, great. :D
  6. Sep 12, 2009 at 11:50 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    correct
  7. Sep 12, 2009 at 12:52 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    thanks for the info, it made my getting a little more lift a lot easier. not by any means cheaper though haha
  8. Sep 12, 2009 at 3:31 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    oh, so if i were to set the front at say 3.5" or so, what would be a good height for the back to keep it more or less level with the front? i was hoping a 1.5" aal would do the trick.
  9. Sep 13, 2009 at 12:43 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    That might not be enough, especially if you are running 33" tires. Look into the All Pro 3" leaf pack or something equivalent. You will have a rear lean with just a 1.5" aal.
  10. Sep 13, 2009 at 1:42 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    wow itd be that much off, huh? ok, i was intending on getting a leaf pack initially but just didn't know what height. thanks for the help!
  11. Sep 13, 2009 at 2:12 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    I would highly recommend getting adjustable uca's with spindles. They will work with no preload on the coilover and will work if you ever want to go up from 3.5 inches. I had a very hard time getting my truck aligned with my spindles and coilovers, even when I had my coilovers set at 0". Get the uca's, you will need them.
  12. Sep 13, 2009 at 11:09 PM
    StaticTaco
    Mitch
    Oahu
    2011 SR5 4WD
    well that's no problem because i already have them on my truck, so i guess all i'd need is to get is the spindles, and a leaf pack to level it. i was paranoid about alignment and what not when i got the 5100s so i sprung for the ucas :)
