Do I really *need* E rated tires?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mmaira2018, Jan 28, 2022.
  1. Jan 28, 2022 at 5:51 PM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I agree, I doubt E load are killing your mileage, its likely the diameter causing more throttle input to maintain speed, and the wider square edged tire increasing wind resistance causing more throttle input to maintain speed.
    Your tent and awning are absolutely hurting your mpg. Getting 14 winter and 16 summer, you are actually doing great on MPG. I've asked some people what they get with 2nd gen 4.0 all built out, they say 10mpg...10!
    I recently learned that E load actually need to be aired up a bit more than a P or C load to have a comparable contact patch, so maybe bump them to 38 or 40psi or up 5 psi from where you have them
    Mmaira2018[OP] likes this.
  2. Jan 28, 2022 at 6:01 PM
    Jesse46
    Jesse46 Well-Known Member
    Jesse
    Orange County, CA
    2017 OR DCSB 4x4
    these are the exact tire i run. I really like them and the mpg drop was negligible, tire noise is a bit loud but I listen to music while I drive and passengers don't seem to care either.
    Tocamo[QUOTED] likes this.
  3. Jan 28, 2022 at 6:10 PM
    frodoz737
    frodoz737 TOP WRENCH
    Texas
    Agree.
  4. Jan 28, 2022 at 6:12 PM
    grogie
    grogie Sir Loin of Beef
    2019 TRD OR AC, 2018 4R Limited, 2006 Jeep TJ
    I have Jeep TJ with Goodyear MT/Rs that went from C rated 32" to E rated 33", and I found no difference in ride or mpg. IMHO get the tire you want and not worry about if it's C or E.
    71tattooguy likes this.
  5. Jan 28, 2022 at 10:16 PM
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    I run Cooper STMaxx 265/75/16 E rated tires and my gas mileage dropped very little.
    I don’t have “E” rated tires to carry a load, I have them to get me home. Living in the mountains and driving a lot of forest and gravel roads. After having a rock rip the thread of a “P” rated tire to where it couldn’t be repaired and a seeing a friends “C” K02 on a JLU get ripped in the same way, two different times. What that happens to a tire on a trail, like Engineer Pass and then finding a place to change it can suck and if it’s in the wrong area, can really suck.
    I’ll stick with “E” rated tires.
  6. Jan 29, 2022 at 7:44 AM
    spence13e
    spence13e Well-Known Member
    NCK
    2021 Barcelona Red Tacoma OR MT
    NA
    2021 OR here. Bought it a year ago last week. Run my business out of it, so it’s loaded to capacity at all times. At 20-21k, I had a rock puncture repaired with the OEM tires. A few days later, another went flat and I took it into Big O for repair. They claimed it ruined, so I made the mistake of buying a set of their house brand 4 ply being as I was there. Should have just bought ten ply then, but they didn’t have what I wanted.
    Fast forward and my regular tire man convinces me to go ahead and buy the next set before the end of the year because I drive a ton and tires can be sketchy to get now. I order a set of Mastercraft AXT 10 ply.
    In the last six weeks, those Big O tires had a total of I think four flats. One rock puncture repaired, then the patch blew out on it (put an old OEM back on to try and then wear the set out), a nail in another, and had a slow leak for a few days. Said screw it and took it in. Had another rock puncture AND a nail in that one.
    Basically got 32k from those Big O. $850 down the tube.
    I like the MC so far. Upped it again from 40 psi to 45. Ride is perfectly acceptable. Verdict is still out on mileage, I think I may lose a bit, but it’ll take a few thousand miles to really tell on that.
    I would have gotten a 6 or 8 ply, but there were absolutely none available. I’m mostly on the highway, but do see enough gravel and rock roads that the peace of mind of a heavier tire is helpful.
    All that said, I had a half ton before that had an odd size and there was no OEM size 10 ply, and I didn’t have any tire related issues in 260k with 4 ply, loaded to capacity just like this one.
    NMBruce likes this.
  7. Jan 29, 2022 at 9:07 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Your wording implied that the tires had a 1000 lb capacity, which is not true
    CherylJane and Mmaira2018[OP] like this.
  8. Mar 30, 2022 at 7:39 PM
    ZMB KLR
    ZMB KLR Member
    Some observations by a lurker...
    I ordered E loads recently. I've read everything from "no difference" to "drives like a dump truck"
    Something that typically sn't discussed is what is the wheel size? Does your truck look like a shopping cart with huge wheels and low pro tires? It's going to feel like a train. The smaller the wheel size, the softer the ride.
    Air down appropriately and chalk, and the difference will be the weight difference in the tire, which equates to about a bag of sand.
  9. Mar 30, 2022 at 8:41 PM
    RebleAZ
    RebleAZ Well-Known Member
    Troy
    AZ
    2020 Cement TRD Off Road
    Fox Performance Elite, RRW -25 RR7H, 295/70/17 Yokohama Geo MT. Alcan Leafs. Much more...
    I am running 285/75/16 Nitto Ridge Grappler “E” rated and they ride pretty stiff. Great off road but street driving is hard and I have been running them a bit lower at 27PSI. I like the confidence off road knowing that I have them though. They seem to be getting louder too and they were pretty quiet when new. Have had balanced and kept it aligned more than a couple times to keep the wear even.
  10. Mar 30, 2022 at 9:13 PM
    Spidicus
    Spidicus Well-Known Member
    Nevada
    19' DCSB TRDOR 4x4
    No you don't.
