Do I want the Rear Leaf TSB if I'm going to install a 3" lift with an AAL rear?
Discussion in 'Suspension' started by Bighit, Oct 9, 2008.
  1. Oct 9, 2008 at 10:06 PM
    Bighit
    Bighit [OP] Active Member
    Utah
    Black TRD Short bed
    3" Tuff Country Lift + AAL rear Magnaflow muffler
    I plan on installing a 3" lift with an add a leaf rear. I understand this will stiffen things up a bit. I was planning on taking my truck in about the Rear Leaf TSB first, but then I got to thinking that the two combined might lead to an overly stiff ride. What's the scoop?
  2. Oct 9, 2008 at 11:33 PM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    Just save yourself the money and just get the TSB done. It will give you a small lift in the rear. The old leaf pack is made up for 3 leafs, the new TSB leaf pack is 4.
  3. Oct 10, 2008 at 5:05 AM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    You want a 3" lift.:cool: Forget the tsb.You'll only get 1" w/that. You can get 2" aal for about $75-80.:) ToyTec carries them.
  4. Oct 10, 2008 at 6:08 AM
    Bighit
    Utah
    Black TRD Short bed
    Right now my back end is definately too soft. I have bottomed coming out of parking lots and over speed bumps. So if I get the TSB first and then the full lift, I'll have a 3X2 lift which sounds pretty good to me, but it will have five leafs in back. Will it result in a rear end that is Too harsh. I'm definately going to get the 3" front, I'm just trying to figure out what to do with the back end.
  5. Oct 11, 2008 at 8:39 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    +1 Skip the TSB and just go with the AAL. Once you get the TSB done you can NOT go with an AAL for additional lift. Once the TSB is done, the only option for rear lift is a block, SuperSprings, Air Lift, of all new springs.
  6. Oct 11, 2008 at 9:07 PM
    BeefTaco
    BeefTaco WESTern Alliance: NORCAL COAST
    Santa Cruz County Ca.
    I have a question I have the new TSB springs and I am ready to put them on. I have the 3 leaf with an aaL right now so my question is I plan to tow a 14' 16' enclosed motorcycle trailer what would be best 4 pack with a block or 3 pack with aal. Its a truck so I am not concered about the ride.
  7. Oct 11, 2008 at 9:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im running an AAL in my TSB spring pack and the ride is nice. Much better than it was with the 3 leaf pack. You can have a spring shop make an AAL for you to fit your spring rate.
  8. Oct 11, 2008 at 9:58 PM
    Neubs
    Maryland
    Wow, you had a custom AAL made? I have not seen anyone run an AAL with the TSB and have always been advised that you can not run an AAL with the TSB, or perhaps no one makes a AAL for the those who have had the TSB done? I know that ToyTec and most other vendors always advise no AAL with the TSB. However, my neighbor was telling me about a local custom spring shop that re-bends factory leafs to your desired spring rate and lift. Is this what you were referring to? Having a custom shop fab a AAL? I have not seen one available through common retailers. IE. ToyTec, Wheelers, etc.
  9. Oct 11, 2008 at 9:59 PM
    Neubs
    Maryland
    Have you towed your trailer with your current set up?
  10. Oct 12, 2008 at 7:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The only reason they say that you cant run an AAL with the TSB springs is because the AAL will contact the spring "clamp" in the rear. 2 ways to handle this: 1. cut the AAL about 1/2" shorter in the rear, or 2: turn the spring around. Personally, I only wanted 1" of lift on top of what the TSB spring pack gave. My Target lift in the rear was 1.75" - 2" lift. The TSB springs gave an initial 1.5" lift, and settled to just under an inch. I went to a spring shop and they weighed all 4 corners of the truck with me sitting in the cab, then we decided how much lift I wanted. They made a long AAL with a 1.25" initial lift as it would settle about 1/4 to 1/3 ". They put a little more arch into the driver side to account for the more weight on that side. The result is a 5 spring pack that will flex just like stock, and rides no different than the TSB springs alone, and the truck sits PERFECTLY level from side to side. Total lift gained with the TSB and the AAL is 2". I couldnt be happier. The price was around $60.00 for the AAL's which I think is a SMOKING deal, considering all the time that was put into it. :) Any local SPring shop can fo the same thing for ya, and thats what I recomend as the spring will be tailored to your truck.
  11. Oct 12, 2008 at 1:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You wont have a stiff road ride all the time. It depends on what kind of AAL you use. I have my OL still, and like mentioned many times, my ride is just like the factory TSB. For the blocks, when you say "Billet", your not meaning aluminum, right?
  12. Oct 12, 2008 at 2:20 PM
    nighthawk87
    nighthawk87 Well-Known Member
    So let me get this straight...If I want to get my 3" lift later down the road then I should not get the TSB done ???
    Would the 3" Toytec lift be level? Would I just get the front if i already have the TSB?
  13. Oct 12, 2008 at 7:33 PM
    Neubs
    Maryland
    Great post Chris! Thanks for the information! :thumbsup: $60 is a smoking deal for custom leafs.
