Do it yourself: scepter gas can spout
Discussion in 'Garage / Workshop' started by ramonortiz55, Mar 14, 2016.
  1. Mar 14, 2016 at 11:03 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I needed a scepter gas can spout but didn't want to pay the Amazon premium of $20
    Figured I could make my own.
    I noticed the threads inside the can spout opening:
    Went to the hardware store and picked up a 2 inch male adapter, 2 x 1/2 threaded bushing, a barb fitting and some fuel hose..
    Glued the fittings together, threaded the barb fitting using yellow teflon rated for fuel:
    Voila:
    **dont forget to use yellow teflon at the 2" male threads**
  2. Mar 14, 2016 at 11:10 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
  3. Mar 14, 2016 at 11:11 AM
    ramonortiz55
    Ramon
    Texas
    stock
    :thumbsup:
    only thing I encountered was a small drip during fueling .. and that is because i didnt teflon the threads on the 2" male adapter.
  4. Mar 14, 2016 at 11:12 AM
    holyfield19
    Bob
    South Carolina
    06 DC TRD Sport 4X4
  5. Mar 14, 2016 at 11:13 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Looks perfect! That's how I did mine, plus teflon. Used a seal off a used oil filter around the base as well :cheers:
  6. Mar 14, 2016 at 11:23 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    what the hell?
    so to avoid spending $20 on a part that works perfectly, you spend $18 for parts, and spent an hour working on it, so you could have a dripping product?
  7. Mar 14, 2016 at 11:26 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Step one: unscrew spout.
    Step two: add teflon
    Step three: screw spout.
    Anything else?
  8. Mar 14, 2016 at 11:27 AM
    beertimecontinuum
    Everett
    I already had all the pieces except the female reducer.:D
  9. Mar 14, 2016 at 11:28 AM
    ramonortiz55
    Ramon
    Texas
    stock
    sweet! yeah. I didnt think about adding the teflon until i saw the leak.. lol
    I was like :bananadead:
  10. Mar 14, 2016 at 11:29 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I do plumbing on the side, so I had a few fittings laying around.
    Only thing I had to go pick up was fuel hose.
  11. Mar 14, 2016 at 11:30 AM
    beertimecontinuum
    Everett
    Yeah, NPT fittings have to have it. Come to think of it I may have used gasoline frindly cement on the fitting. I remember welding the PVC that way.
  12. Mar 14, 2016 at 11:32 AM
    beertimecontinuum
    Everett
    Cough* work consumables here cough*
  13. Mar 14, 2016 at 11:33 AM
    la0d0g
    la0d0g Its 4 oÂ’clock somewhere
    running for the hills
    For crawling not hauling
    What happened to the other thread for this? Did it get nuked?
  14. Mar 14, 2016 at 11:34 AM
    ramonortiz55
    Ramon
    Texas
    stock
    :notsure:
  15. Mar 14, 2016 at 11:36 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Does it flow well without any vent system (none that I can see anyway)?
    Wait...is that little hole the vent? Looks partially blocked by the PVC male fitting.
  16. Mar 14, 2016 at 11:37 AM
    la0d0g
  17. Mar 14, 2016 at 11:43 AM
    ramonortiz55
    Ramon
    Texas
    stock
    yes, there is a little hole vent on there, it flows well.
  18. Mar 14, 2016 at 11:43 AM
    ramonortiz55
    Ramon
    Texas
    stock
    la0d0g[QUOTED] likes this.
  19. Mar 14, 2016 at 11:44 AM
    Sig45
    Mark
    Maine
    Nice...thanks. Any thoughts on what would work for a cap on the end of the fuel hose?
  20. Mar 14, 2016 at 11:46 AM
    la0d0g
    I use a PVC end cap. Works well, I don't transport using it. Only around camp when I'll be accessing the gas multiple times.
    ramonortiz55[OP] likes this.
