Do snorkels decrease throttle response?
Discussion in 'Off-Roading & Trails' started by Sheepdog, Apr 13, 2010.
  1. Apr 13, 2010 at 6:03 PM
    Sheepdog
    Sheepdog [OP] Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    I was wondering if they have any adverse affects on the engines like poor throttle response or other things. Does anybody know how they act on the 3.4L's?
  2. Apr 13, 2010 at 6:09 PM
    Sheepdog
    Gary
    San Diego, CA
    That's what I figured too, But then I also thought; would it be kinda like a CAI because it's breathing the air from outside the engine compartment... So wouldn't the throttle response be better?
  3. Apr 13, 2010 at 6:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    It is about the best CAI you can get. I havent noticed any decreased throttle response on the trucks I have driven that had them...
  4. Apr 13, 2010 at 6:17 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    just cause the piping is so long there still is air in the tubing so its not like it has to travel all that way before you suck any in...at least thats how i see it :confused:
  5. Apr 13, 2010 at 6:25 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    yea i dont see why there would be, there will always be air in the snorkel tube so its not like you will have to suck air all the way in from the outside everytime you touch the gas.
  6. Apr 13, 2010 at 6:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Agreed. One of these days, I hope I can dyno one....
  7. Apr 13, 2010 at 6:34 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    but that still won't give you completely accurate info at highway speeds because some air would be rammed down into it. Don't you think?
  8. Apr 13, 2010 at 6:50 PM
    Sheepdog
    Gary
    San Diego, CA
    So would you guy's advise getting one then?
  9. Apr 13, 2010 at 6:53 PM
    08pretaco
    Oliver
    az
    if you dont want to hydrolock your engine and do alot of driving in high water, id get it
  10. Apr 13, 2010 at 6:55 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I think the more important question would be do you need one?
  11. Apr 13, 2010 at 6:58 PM
    98_Mud_bug
    lucedale Ms.
    if you use it then go for it, but if you get high enough to get water in your intake then your gonna have alot of other problems that just hydrolocking your engine, the floor boards will probably take water, diff's will take water, and it will be alot more trouble than i think its worth. you always have to worry about stuff laying in the bottom of where ever your driving, big holes and such that will sink your truck. but on that note they look cool as hell and are alot cheaper than rebuilding the engine.
  12. Apr 13, 2010 at 7:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    True.
  13. Apr 13, 2010 at 7:25 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    A snorkel will not make you be able to cross rivers, there are MANY things that you need to do in parallel to make your rig be able to traverse deep water, and if you dont do them all, a snorkel is essentially just for looks....fact is, a gasoline engine is not ideal to begin with. You need to move your electronics (ECU up higher), diff breathers, actuator breathers, trans breathers, seal engine electronics, etc. There seems to be a common misconception that if you throw a snorkel on, you can drive underwater, and that is NOT true. In reality, a good bow wave can get you through VERY deep water, and you would be better off doing mods like all the breathers before a snorkel, as a bow wave will clear water from your airbox, but not your rear diff and trans diff.
    In realitly snorkels are more commonly used for dust conditions (this is what they were mainly designed for...australia has a LOT more dust than water crossings) THey allow your engine to sucks air from up high while large dust particles fall down.
  14. Apr 13, 2010 at 7:28 PM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yup, this is the main benefit from a snorkel, other than the fact that they look awesome.
  15. Apr 13, 2010 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They are still used for fording water. Ive crossed lots of water in which the vehicle was completely submerged (not the Tacoma). Yes, Water can hurt things. After I run around in deep water, I drain and fill all fluids, and check connections. Not recomended you do it often, as water can destroy expensive things, like your alt., and get inside and mess up the interior, not to mention all the electronics inside like the AC, Dash, etc.
  16. Apr 13, 2010 at 7:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought you were being nice??
  17. Apr 13, 2010 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    puto.
  18. Apr 13, 2010 at 7:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek:
  19. Apr 13, 2010 at 7:44 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    The only adverse effect that i have seen so far is that in severe blizzards the opening can get clogged, however to remedy this all you have to do is turn the snorkels head around. The truck feels much smoother and slightly more powerful over stock as others have stated it's effectively the best CAI you can get.
    In NJ there's some seriously deep holes that having a snorkel adds an extra sense of security, since a hydrolocked motor would be a serious expense. The water/mud can do a serious amount of damage on other components, but the engine itself will come out relatively unscathed.
  20. Apr 13, 2010 at 9:21 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Fascinating. I did not know that. :)
    I can attest that I went through one dust storm in the Yuha desert and my factory filter was done.
