Do the 2.4L , 2.7L 4-cyl 'wind out' on the highway?
Discussion in '1st Gen. Tacomas (1995-2004)' started by cycledrum, Feb 1, 2008.
  1. Feb 1, 2008 at 9:04 AM
    cycledrum
    cycledrum [OP] Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    My Toyota is a 1988 pickup, 4WD, 5-spd manual, 2.4L 8-valve 116 HP
    at 70 mph indicated (with 31" tires) tacho indicates 3,000 rpms which gets annoying cruising the highway.
    How does the ubiquitous 2.4L 16 valve 142hp cruise? Can it climb some freeway grades or like mine, won't do over 50 mph (pedal to floor) on some grades?
    How about the 2.7L used in the prerunners, how's that?
    thanks ahead.
    (can you tell I'm getting ready to unload my pickup this year?)
  2. Feb 1, 2008 at 9:08 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    My PreRunner 2.7L hits 2,500 RPM at 75 MPH. Of course, it has quite a bit more range than the older 2.4L have. Also, that is with a 4.10 rear axle and large tires.
  3. Feb 1, 2008 at 9:24 AM
    cycledrum
    Union City, CA
    Thanks for the feedback!
    Is the 4.10 rear axle and tires stock size?
  4. Feb 1, 2008 at 9:29 AM
    cycledrum
    Union City, CA
    Sorry, just looked at your mods ... I'm guessing the rear axle is stock and the 265 tires come with the TRD package.
  5. Feb 1, 2008 at 10:28 AM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    The rear axle (4.10) is stock with the 2.7L manual tranny PreRunners. The 265s were added on by me since the stock Dunlops weren't good tires at all.
    Toyota hasn't offered a TRD 4 cylinder Tacoma since 2002. The highest package you can get is the SR5. However, there is now a suspension TSB that allows you to get TRD suspension on your 4 cylinder PreRunner (05+). That is what I have. ;)
  6. Feb 1, 2008 at 10:29 AM
    Motorkopf
    Motorkopf Conservative
    Victorville, CA
    05 PreRunner SR5 2.7 Manual
    3" Toytec lift, Susp TSB, Detroit True Trac, Carr side steps.
    I have a 2.7 with 265 70 16 tires (stock) whereas Mark's tires are a tad bit larger than stock. My engine speed at 70mph ground speed is right around 2500 rpm. Generally I have no problem maintaining highway speed on a grade unless it's pretty steep or there is much head wind. The 160hp 2.7 seems to have plenty of power. I still feel like I'd like a bit more power at highway speeds for passing, but at city speeds the power is more than sufficient and at highway speeds its ample. I have no regrets with the 2.7 (vice the 4.0 V6) and with the headers/catback I intend to get, I think I'll be completely satisfied with the power.
