Do you check your oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AnotherSilverTaco, Apr 21, 2012.
  1. Yes, every fill-up because...
    62 vote(s)
    12.6%
  2. Yes, sometimes because...
    259 vote(s)
    52.5%
  3. No, because...
    93 vote(s)
    18.9%
  4. No, but I should because...
    73 vote(s)
    14.8%
  5. Other because...
    6 vote(s)
    1.2%
  1. Oct 12, 2012 at 4:28 PM
    #101
    DriverSound
    DriverSound Señor Member
    SoCal
    15 DCSB OR 4x4 & 15 Mustang GTPP
    Too few to list. 10 4runner SR5 4x4- 09 Pre-Runner TRD-OR AC- 14 Prius Two- 08 xB 03 Tacoma 5spd TRD OR 4x4
    1-2 months depending on how often I use the truck along with tire pressure. Quick check on my daily, once a month.
    I wouldn't worry about checking oil more often regardless of miles unless oil level is low before an oil change.
  2. Dec 3, 2012 at 5:03 PM
    #102
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Oil is for chumps. I don't use oil.
  3. Dec 4, 2012 at 7:44 AM
    #103
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Unicorn tears have far superior lubrication characteristics than oil.
  4. Dec 4, 2012 at 12:15 PM
    #104
    Mr.Gadget
    Mr.Gadget Well-Known Member
    NC
    2011 DC 4x4 SR5 SB/2012 DC 4x4 SR5 LB
    I do time to time.
    I park the same place at work and home and make sure the ground is clear on both every day I walk to the truck.
    No dripping, then it should be fine so check when I can.
  5. Dec 24, 2012 at 4:13 PM
    #105
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 2 Hella 4000 HID, 1 Cibie Halogen. Bilstein 5100s Ride Rite Air Bags
    No because these trucks don't ever lose or drip oil. Change it every 4,000 +/- miles (3,000-5,000).
  6. Dec 24, 2012 at 9:21 PM
    #106
    MikeyMcFly
    MikeyMcFly Well-Known Member
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Painfully stock.
    I check mine every fill up. I do wish I had an oil pressure gauge on it from the factory. I added one on my car along with an oil temperature gauge and monitor those and adjust my driving habits accordingly.
    IMHO all the oil light on the dash tells you is that you did expensive damage to your motor as unless Toyota is different, the light will not illuminate unless the pressure is under some ridiculously low value (like 5 psi or so).
  7. Dec 25, 2012 at 1:02 AM
    #107
    808TRDTaco10
    808TRDTaco10 Black Sand Mirror
    Justin
    Big Island--->Oahu, Hawaii
    10 AC TRD OR 4x4 BSP; 08 Reg Cab 5 spd 4x4
    TRD Off Road 265/75/16 Goodyear Wrangler Duratrac Load Range C | Toytec Ultimate Lift with Emu Dakar Leaf Packs | 3* Axle Shims, CB Drop, Sway Bar Relocates | AVS Vent Visors, AVS Bugshield | Scangauge II | Smoked Eagle Eyes Ebay LED Tails | Wet Okole Seat Covers | Weather Tech Floor Liners | Pop n Lock | OEM Bed Mat | Truxedo Lo Pro QT Tonneau Cover | TRD Cat Back Exhaust | Aftermarket Alarm System | Pro Coat "Electronic Rustproofing"
    On this truck I check the oil once a month, along with the other fluids and check the tire pressure.
  8. May 2, 2013 at 6:08 PM
    #108
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Check it when I'm under the hood. Maybe once or twice a month on average.
  9. Aug 4, 2013 at 5:20 AM
    #109
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    Unless you have a burner or leaker, the Toyota's just don't use oil, when I first switched to synthetic, I had to add about 1/2 quart the first 5000 miles, but never had to add since....remember, when you fill the 3.4L, it takes a bit more than 5.1 quarts to fill, you are already a bit low even though you may think you are full up....I have an extra quart that last three oil changes before another is needed to top off at change time...
    I check the oil maybe two, three times between changes....
  10. Aug 5, 2013 at 1:12 PM
    #110
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    I check mine if I sense something isn't right, or typically check every couple of weeks or so. One thing I always do is look for drips when I park and when walking back to the truck. That's always been a habit of mine since getting into the car buisness. Check the pavement below any vehicle for any signs of any kind of leaks. If I ever see a puddle that I don't remember being there when I parked the truck then I definently check the oil, trans, and radiator fluid just to be safe.
  11. Aug 9, 2013 at 9:31 PM
    #111
    kjmc
    kjmc Well-Known Member
    Kelly
    Alliston,Ontario,Canada
    2007 TRD-SR5 4x4 DCAB
    Truxedo Lo-pro-Qt Sirius Radio
    I check my Oil about every 2000 Km and change every 8000 Km.
    I also look for wet spots on the ground (touch wood ) :rolleyes:
    none yet with 192,000 Km's.
  12. Aug 10, 2013 at 7:22 AM
    #112
    andjenliang
    andjenliang Well-Known Member
    Andew
    SoCal 909
    10 DCSB PreRunner V6 TRD Off Road
    Stock
    I think i might lose more oil constantly checking my dipstick than my engine burns...
  13. Aug 10, 2013 at 2:38 PM
    #113
    invertedAv8r
    invertedAv8r Member
    Alberta
    09 Tocoma TRD OffRoad
    ...It reminds me to change it out. If I never checked the oil it would be outta sight, outta mind...
  14. Aug 10, 2013 at 3:01 PM
    #114
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2000 SR5 TRD 4x4 Ext Cab V6 Manual
    I have checked the oil (in the sense of the term we're using here) about 4 times since I have owned my 2000 Tacoma. 208,000 miles.
    I do my own oil changes ~5k miles and pay attention to how the truck drives. It doesn't leak. These engines don't burn oil... and if they do, there is something seriously wrong and I'd be able to tell. If I ever get indicators that something is amiss, I'll start checking. I guess that makes me an irresponsible jackass, wouldn't be the first I've been accused of that!
  15. Aug 10, 2013 at 5:10 PM
    #115
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    They have Interstate Highways in Hawaii? :cool:
  16. Aug 10, 2013 at 5:27 PM
    #116
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, go figure.
    Still waiting for that bridge.
  17. Aug 11, 2013 at 1:14 AM
    #117
    ARB1977
    ARB1977 Don't be a dick
    North Texas
    15 Speedway Blue DCSB Prerunner 4.0L
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I used to check mine every fill up. Now once a month. Doesn't leak or burn.
  18. Aug 11, 2013 at 2:10 AM
    #118
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    A little lift & some extra steel....
    Same here
  19. Aug 11, 2013 at 5:56 AM
    #119
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser
    Stuff
    For anyone who wrestled in high school/ college, this is the first thing I though of
  20. Aug 11, 2013 at 7:08 AM
    #120
    george3
    george3 Well-Known Member
    new jersey
    tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
