Do you need your CAT CON sheild?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flightcancled, Jun 3, 2010.
  1. Jun 3, 2010 at 3:00 PM
    flightcancled
    flightcancled [OP] Addicted
    Syracuse NY/ Nantucket MA
    Camper top with racks, Custom fogs behind lower bumper. Interior LED lighting, Rock Lights, Hella 500s with upraged bulbs behind black billet grill, AAL, Front 5100s
    Searched and found that other people have had this issue, but didn't find a resolution:
    Today the noise I have had building for the past two weeks finally got bad enough to be detectable while idling. It seems that the shield on my catalytic converter is rattling. Even if I tap it while parked with the engine off I get a pretty nasty - PO'ed bull-frog type sound that is really loud at 1500 RPM
    Can I just rip that thing out? If I can salvage it I will since it protects the cat and all, but the noise has got to stop. I think its just dented and rubbing somewhere, but in any case the bolts and fasteners all have to be drilled out and replaced to trouble-shoot the issue.
    Thanks!
  2. Jun 3, 2010 at 3:59 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    The converter gets really hot...I imagine you'll end up melting your carpet or something if the shield is removed.
    Can't you figure a way to tighten up the fasteners mounting it instead?
  3. Jun 3, 2010 at 5:19 PM
    flightcancled
    The shield I am talking about is the aluminum one surrounding the cat not the one bolted on the frame. Is that also for heat?
  4. Jun 3, 2010 at 7:03 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I had one that rattled at 2500 RPM on another truck I had. Took it to the exhaust shop and the guy said he could weld it back on the cat or he could rip it off. He said it wasn't 100% necessary and could break loose again, so I told him to take it off. He said it was just to keep the cat from catching grass on fire when off road (??) Not sure about that, but that truck was fine for several more years. Just my experience.
  5. Jun 3, 2010 at 7:08 PM
    flightcancled
    Thanks for the info looks like it's coming off.
  6. Jun 3, 2010 at 7:12 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Yes, Catalytic Converters Will Ignite Grass. If You Keep That In Mind, You'll Never Return to a Smoldering Truck.
  7. Jun 4, 2010 at 5:39 AM
    buddywh1
    Philly PA
    07 DC SR5 4x4
    x2
    I remember that when cat's first appeared on cars in the 70's...it even happened to my father-in-law. There were scorch spots all along I-35 in Oklahoma from the cat fires. It's more of a problem for cars of course, being lower to ground, but an off-roader is more likely to wander into, and park over, tall grass too.
  8. Jun 4, 2010 at 8:19 AM
    flightcancled
    Hmm. Well I am hoping that it is as simple as a rock lodged in the housing or something that I can remove. The issue is to get it off since the bolts Toyota used have all rusted to bits.
  9. Jun 7, 2010 at 6:03 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use large stainless steel band straps to tighten up the sheild. If the sheild isn't rattling, the catalyst honeycomb could have broken loose. It will cause problems in addition to noise.
    Also, the cat burns up the unburned fuel from the engine. Powertrain contol modules have been known to fail and keep the mix too rich and overheat the cat enough to set the vehicle on fire. Keep the sheild if you can.
    Good luck.
  10. Jun 13, 2010 at 1:52 PM
    flightcancled
    I waited until the rattle got so bad it was doing it at idle at which point I jumped under the truck to have a look. I guess it got justled about and was rubbing against the side. After prying on it to pull it towards the passenger side and widen out a small part of the sheild I got the rub fixed.
    Thanks for the help and info gents!
    :cheers:
  11. Jun 13, 2010 at 1:56 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    I was just about to confirm that, yes, it can set off a grass fire.
