Do you upgrade your spare?
Discussion in 'Wheels & Tires' started by Polymerhead, Oct 23, 2010.
  1. Oct 23, 2010 at 4:55 PM
    Polymerhead
    Polymerhead [OP] Well-Known Member
    Missouri
    '18 TRD Limited Inferno...Tundra!
    So, I'm thinking I can get some DuraTracs before winter. I'll be getting the 265/17/16s (no, I mean 265/75/16) since I'm @ stock height. Should I get a larger spare as well? No offroading for me at this point (truck is <1 week old) so if I have a flat it's probably going to be on interstate. If I switch out tires as needed to keep 2 good tires in the rear, would I be OK running one 265 up front and one stock spare long enough to go 10 or 20 miles to the dealership?
  2. Oct 23, 2010 at 5:37 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I think you have a mistype. Are you changing the tire size and worried about the spare being a size down or are you worried about the spare being a different tire brand/tread pattern?
  3. Oct 23, 2010 at 5:40 PM
    Polymerhead
    Missouri
    This. If you're telling me that the 265's are no bigger in diameter than the factoy tires, then it's a moot point. I think there should be some difference though. You're right about a mistype. I was thinking 75 and typed 17. Will edit original post, thanks.
  4. Oct 23, 2010 at 5:46 PM
    Pugga
    Massachusetts
    That's what I was asking, what is your factory tire size? Check out the tire size calculator at the top of this page to find the difference in size between your stock size and your upgraded size. I upgraded from the 245/75R16 to 265/65R17 and never upgraded the spare. At some point, if I can find a deal on a spare, I'll swap it out but because the overall heights are identical, I see no reason to change the spare. Even in an emergency situation, a slight difference in the spare tire size will be ok for a short distance to get you to a shop.
    EDIT: I looked up the tire size difference, if you're going from a 245/75R16 to 265/75R16, your tires will be 1.19 inches larger than the spare. You just have to be mindful of this when you use your spare and take it easy. If you have the opportunity to upgrade the spare, obviously it would be a much better solution but not necessarily a requirement.
  5. Oct 23, 2010 at 5:57 PM
    Polymerhead
    Missouri
    Cool, thanks for the advice. I should be good to go then. Obviously if I really build her out and start running trails I'll have 5 matching rims.
  6. Oct 23, 2010 at 6:05 PM
    Griztaco
    Griztaco Well-Known Member
    ID
    TRD
    I went up to 265/75/16 and traded out the spare with similar size. Found a used one for 20 bucks. I say you do the same so you dont have to worry about it.
  7. Oct 23, 2010 at 6:16 PM
    Polymerhead
    Missouri
    Yeah, for $20 it's definitely worth it. I'll keep an eye out after I upgrade the 4 road tires.
  8. Oct 23, 2010 at 6:55 PM
    primer
    primer Well-Known Member
    T
    OK
    06 SS Mica AC 4x4 TRD Off-Road
    (Mostly) debadged, Homelink mirror, Elevated rear diff breather, LED illuminated 4x4 switch, Color matched grill surround, Bed cover, Ivan Stewart wheels, Bridgestone 265/75 Dueler AT Revo 2 tires
    Don't want to hijack, but does that mean that 265/75/16 will in the spot where the spare lives without any trouble?
    Thanks
    TL
  9. Oct 23, 2010 at 7:00 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I didn't upgrade my spare, but I plan to eventually, but with some cheaper full-size brand (i'm running duratracs as well). You won't have a problem going a short distance with the smaller spare though, which is what I believe you are asking.
  10. Oct 23, 2010 at 7:01 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    Wow, great idea, no sense buying a new one since it's only going to used as a spare rarely, if ever. I'm keeping an eye on craigslist now lol
  11. Oct 24, 2010 at 7:38 PM
    Griztaco
    ID
    TRD
    It fits fine, a little snug, but no problems. I have had that spare in there for about 6 months.
  12. Oct 24, 2010 at 7:53 PM
    c2thegreat
    c2thegreat Well-Known Member
    Ol' Virginny
    09 4 banger
    Readylift sst,31in. mts,TRD sport bilstein rear shocks,new head unit,bedlined tool box,fishing rack,35% tint,fogs
    Definately theres no point in paying a ton of money for a tire thats gonna sit under my truck and dry rot anyway. I got one at a used tire shop.
  13. Oct 25, 2010 at 4:58 PM
    primer
    T
    OK
    Good news.
    Thanks
    TL
  14. Oct 25, 2010 at 8:05 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I just put a 265/75R16 tire on the stock spare rim in the stock location last week on my 2011 std cab. Fits.
