Does anybody miss the manual clock in the center dash?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by corpuschristi, Aug 17, 2015.
  1. Aug 20, 2015 at 4:23 AM
    #61
    pughfish
    pughfish Well-Known Member
    William
    Fayetteville, NC
    2024 Toyota Tacoma Limited
    So, is it durable to add the clock to the 2015 Tacoma?
  2. Aug 20, 2015 at 4:26 AM
    #62
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    So sounds like you do know how to wire it then? Any help is appreciated.
  3. Aug 20, 2015 at 4:26 AM
    #63
    J2times702
    J2times702 Member
    Justin
    Virginia
    Bonestock Sport 4x4
    I agree, it's rather annoying the time is only visible on the main screen.
    I could careless about the screen in the new models. I would take a regular stereo with the clock display and temp gauge in the rear view mirror. All I really appreciate about the screen is the back up camera but that use to be in the rear view mirrors as well.
  4. Aug 20, 2015 at 4:29 AM
    #64
    J2times702
    J2times702 Member
    Justin
    Virginia
    Bonestock Sport 4x4
    Also, the weather for the screens in the new tacomas is only viewable when you have connection, when I would go to the mountains it would never update until I went back down.
    Kinda irritating, when the temp in rear view never goes away no matter where you are...
  5. Aug 20, 2015 at 5:04 AM
    #65
    adio
    HI
    So looking at the wiring diagram. Would it be ok to tap into wire #11 for wire #13 for illumination? As for wire #14 where can we tap into to power the clock?
    I'm such an amateur on anything that's gets to do with wiring and sh** haha.
  6. Aug 20, 2015 at 10:00 AM
    #66
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    It does look like tapping into #11 would work for illumination.
  7. Aug 20, 2015 at 10:10 AM
    #67
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Not yet but I might in a few years IF I buy another Tacoma. Toyota must think I am in the minority because I prefer stuff like outside temp, Homelink, & the clock over a dampened tailgate, and a GoPro mount.
  8. Aug 20, 2015 at 5:23 PM
    #68
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    Not sure about that.
    On my truck, the Hazard switch does not light up until the parking/headlights are on, whereas the clock is always on, and dims when the parking/headlights are on.
    I would think you would want #13 to tie into something that dims with the headlights on, like the radio illumination circuit.
  9. Aug 20, 2015 at 7:40 PM
    #69
    shakerhood
    Southern Ohio
    Yeah you might be right, that schematic did say clock on it though for #11.
  10. Aug 21, 2015 at 3:28 AM
    #70
    adio
    HI
    ^^ do you know where we could tap into then from the surrounding wires?
  11. Aug 21, 2015 at 6:49 AM
    #71
    shakerhood
    Southern Ohio
    Since I will be putting in a mirror with outside temperature and compass, I will ask if they have one that also includes a clock.
  12. Aug 21, 2015 at 9:06 PM
    #72
    shakerhood
    Southern Ohio
    I hope I understand your schematics, I should tap the one you have marked #4 and run it to pin #14 at the clock and the one you marked #6 to pin #13 at the clock?
  13. Aug 21, 2015 at 9:21 PM
    #73
    tomwil
    East Coast USA
    2014 Reg Cab 4x4
    No, it appears #4 (dome) goes to #13 (clock), and #6 (tail) goes to #11 (clock) which may already exist because of the hazard switch illumination.
  14. Aug 21, 2015 at 9:30 PM
    #74
    adio
    HI
    @caribe makaira you're awesome man.
    Would it be possible to find those wires in the surrounding area by the HU instead of running wires all the way to the fuse box?
  15. Aug 21, 2015 at 9:39 PM
    #75
    Prerunner_gunther
    Prerunner_gunther Well-Known Member
    Scott
    The tacoma stamped where the clock was looks cheap and stupid!
  16. Aug 21, 2015 at 10:22 PM
    #76
    shakerhood
    Southern Ohio
    Agreed
  17. Aug 30, 2015 at 9:09 PM
    #77
    shakerhood
    Southern Ohio
    Did you get the clock installed during that appointment?
  18. Aug 31, 2015 at 4:09 AM
    #78
    pughfish
    William
    Fayetteville, NC
    Yes! The dealer installed it for $127. I dropped my truck off that morning. The service advisor could not explain how it was done.
  19. Aug 31, 2015 at 4:14 AM
    #79
    adio
    HI
    Dang for 127$. Hmm I was thinking about just running those wires myself. So you think any dealer can pretty much do it, and you did have to order that separate clock/HAZARD switch part right?
  20. Aug 31, 2015 at 4:20 AM
    #80
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
