Does anybody miss the manual clock in the center dash?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by corpuschristi, Aug 17, 2015.
  1. Nov 24, 2015 at 7:17 PM
    #101
    GratefulTaco
    GratefulTaco Well-Known Member
    Alabama
    09 Super White Pre-Runner Double-Cab TRD Sport
  2. Nov 25, 2015 at 8:15 AM
    #102
    ttcpres
    ttcpres Member
    Keith
    2015 Tacoma
    Ok gang, if you're still following along, the second repair wire connects to terminal 11, (hazard switch illumination and clock). In summary, to wire the clock module in the 2015 Tacoma, you need 2 repair wires, one connects to terminal 11, the other to terminal 14. Shop around for the parts. Prices vary by big differences. Thanks to everyone for you input. I'm happy this effort is closed. But sure nice having a clock when my display screen is off.
    Norton likes this.
  3. Nov 25, 2015 at 1:18 PM
    #103
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    So where'd you end up tapping into for 11 and 14?
    More info please.
    shakerhood likes this.
  4. Nov 25, 2015 at 1:57 PM
    #104
    adio
    HI
    This was posted on page 4. 11 could tap into the tail source but for 14, which ACC can we tap into? @caribe makaira
  5. Nov 25, 2015 at 2:11 PM
    #105
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    installed pics ?
  6. Nov 25, 2015 at 2:13 PM
    #106
    ttcpres
    ttcpres Member
    Keith
    2015 Tacoma
    11 & 14 tap the hot lead. I used a crimp.
  7. Nov 25, 2015 at 2:20 PM
    #107
    adio
    HI
    As in where?
  8. Nov 25, 2015 at 2:30 PM
    #108
    ttcpres
    ttcpres Member
    Keith
    2015 Tacoma
    Tech used a tester. Not sure what terminal it feeds. Can look at the harness diagram I saw in this thread.
  9. Nov 25, 2015 at 2:35 PM
    #109
    adio
    HI
    This diagram.
  10. Dec 5, 2015 at 6:12 AM
    #110
    adb243
    adb243 Member
    Atlanta GA
    15 PreRunner
    I have a 2015 and just did the swapover to a hazard switch w/clock. I bought a hazard switch w/clock assembly off of ebay for $95. If you want the clock to have white numbers and you want the hazard button to be black instead of silver make sure you get P/N 84332-04100 which is off of a 12-14 tacoma. I bought 2 terminal repair wires p/n 82998-12690 online from toyota dealer for about $35 shipped. There are 2 wires missing for a 2015. The battery and ACC. I just tapped into the radio battery and ACC circuit because it was right there. I have a entune plus non nav non JBL radio. The repair wires get plugged into pins 13 & 14 on the hazard switch assembly connector. Pin 13 is constant 12v and pin 14 is ACC. I ran pin 13 on hazard switch to pin 4 (Diagram says blue w/yellow stripe but mine had white wire w/blue stripe)on the radio connector that has 10 pins. Then I ran pin 14 on hazard switch to pin 3(grey wire) to the same radio connector. Check pins 3 and 4 with a meter to be sure. I used wire taps to connect the wires. Took about a hour and works great.tacoma radio power.jpg tacoma clock.jpg
  11. Dec 5, 2015 at 6:22 AM
    #111
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    tinker_troy and Norton like this.
  12. Dec 5, 2015 at 12:16 PM
    #112
    adio
    HI
    Nice.
    So it is confirm that it's pin 13 and 14. So why'd the other guy used 11 and 14?
    Question, when looking at that hazard switch connector, are you looking at it from the back or the front of the connector for the pin layouts?
  13. Dec 5, 2015 at 4:34 PM
    #113
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Worked perfectly! Thanks so much for making it so simple for us that are electrically challenged.
    adb243[QUOTED] likes this.
  14. Dec 5, 2015 at 4:40 PM
    #114
    nazlax10
    David
    Woodstock, GA
    To answer your question the picture of the connector here is as if the switch is in the vehicle. So if you're looking at the back of the connector(the side that doesn't plug in) 14 is in the bottom left and connects to the gray wire and 13 directly right of 14 connects to the blue and white wire.
    adio[QUOTED] likes this.
  15. Dec 5, 2015 at 5:03 PM
    #115
    adio
    HI
    Roger that.
    Will attempt this tomorrow.
    Thanks.
  16. Dec 5, 2015 at 7:32 PM
    #116
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Let us know how it goes and snap a few pics if you get the chance.
  17. Dec 5, 2015 at 7:35 PM
    #117
    nazlax10
    David
    Woodstock, GA
    20151205_192948.jpg 20151205_193224.jpg My swap completed.
    adio likes this.
  18. Dec 5, 2015 at 8:14 PM
    #118
    adb243
    adb243 Member
    Atlanta GA
    15 PreRunner
    Glad the swap worked out for you!
    nazlax10 likes this.
  19. Dec 5, 2015 at 8:35 PM
    #119
    shakerhood
    Southern Ohio
    Thanks for posting, I had hoped to see the install pics, also from what I am seeing, that is actually the early style clock because of the Orange lighting, the 12-14 Clock Assembly should be Blue.
  20. Dec 5, 2015 at 8:49 PM
    #120
    nazlax10
    David
    Woodstock, GA
    You're correct. This Is from a 2006 Tacoma. I picked that one because the Orange matches the surrounding lights in the switch.
