Does anybody miss the manual clock in the center dash?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by corpuschristi, Aug 17, 2015.
  1. Jan 1, 2016 at 8:21 PM
    #141
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    If anyone else misses the stand alone temp/compass gauge that was featured in the earlier 2nd gen model years, it's now possible to do the mod. Got it done this past Tuesday. Write up soon to come.
    55AC2A54-CED1-4F52-BFE2-77E3CB8A12B9_zps_45200964fc5c3dcdbde12cdc682b0d35c3f6a2a2.jpg
    1E611EC6-D637-409F-B847-5306B8148002_zps_280dc318226945dfcb2850ead8cd0514e527cfe1.jpg
  2. Jan 1, 2016 at 9:19 PM
    #142
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Thanks for the clock info and that's a great idea as that front sunglass storage spot is pretty much useless.
  3. Jan 1, 2016 at 10:40 PM
    #143
    adio
    HI
    Yups, exactly why I did the mod. Can't even fit regular sunglasses.
  4. Jan 1, 2016 at 11:42 PM
    #144
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Nice work! I just bought the Gentex 453 otherwise I'd probably look at doing this too. Only complaint about the gentex 453 is it doesn't appear to be available in white display like the rest of my lighting... But pretty small detail really. I like how what you did finishes off looking factory equipped :thumbsup:
  5. Jan 2, 2016 at 8:10 PM
    #145
    adio
    HI
    Thank you sir. Yups love doing some simple and subtle mods. More in line of keeping everything stock/oem-ish as possible.
  6. Jan 2, 2016 at 8:15 PM
    #146
    big_jarv
    big_jarv Well-Known Member
    2020 TRD Pro
    I also just bought a gentex mirror or I would've done this.
    I had created a thread asking if it was possible.
    I'm interested for your write up.
  7. Jan 2, 2016 at 8:38 PM
    #147
    shakerhood
    Southern Ohio
    I did the mirror also, never crossed my mind that the old style would fit right up in there or I would have gone that way too.
  8. Jan 2, 2016 at 10:44 PM
    #148
    adio
    HI
    I also wanted to go the mirror route, plus at first I wanted to put the main switch from Switch Pros kit on that temp/compass housing. After looking at the wiring for that gauge it's pretty much a stand alone unit, all it needed was power and illumination, run the temp ambient up front, tap into the VSS, calibrate it, and you're pretty much set.
    big_jarv[QUOTED] likes this.
  9. Jan 5, 2016 at 8:18 PM
    #149
    shakerhood
    Southern Ohio
    After a lot of searching I finally located a Clock out of a 2012, these are not easy to find. Anyways I also forgot to ask you guys that did the conversion, does the clock dim as it should when you turn the headlights on?
  10. Jan 5, 2016 at 10:02 PM
    #150
    shakerhood
    Southern Ohio
    Did you try installing that yet?
  11. Jan 5, 2016 at 10:08 PM
    #151
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I could be wrong but I think that bottom pic is a picture of his truck (installed). If not it definitely looks like a newer model with the older temp / compass installed. Turned out really well.
  12. Jan 5, 2016 at 10:11 PM
    #152
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    temp gauge is uselessssss. Can't trust it. Some days it's close other its ten degrees off. I like having the clock even tho I have one with my kenwood HU
  13. Jan 6, 2016 at 12:35 AM
    #153
    adio
    HI
    It's already installed. Yes bottom pic is with it installed with the newer overhead console.
    I'm going to disagree. The temp and compass is pretty much spot on. It's a lot more accurate then the temp on the headunit(13-15). Plus it's instant temp rather then waiting for the headunit to refresh to your current location.
    Edit. FYI. 2009 and above(not sure up to what year Toyota kept the gauge up to) pulls temp from the AC amplifier. so I'm not sure how accurate/inaccurate the temp would be. Where the 2008 and below pulled temp straight from the ambient air temperature sensor that's mounted in the front of the radiator just below the hood release latch.
  14. Jan 6, 2016 at 3:50 AM
    #154
    adio
    HI
    I may have the part number for the 12-14 clock/hazard part.
    Yes it does dim when you turn on the corner lights/headlights.
  15. Jan 6, 2016 at 7:05 AM
    #155
    shakerhood
    Southern Ohio
    The part number on the clock I scored is from a 2012 and is 84332-04100. Glad to hear that it dims as it should.
    adio likes this.
  16. Jan 6, 2016 at 8:27 AM
    #156
    sapperguy
    sapperguy Well-Known Member
    craig
    09 SR5 DCLB
    I have a clock that I'm wanting to trade for a non-clock.....
  17. Jan 6, 2016 at 8:35 AM
    #157
    shakerhood
    Southern Ohio
    If you have a 12-14 clock, you should be able to trade in a heartbeat as those clocks are hard to find, I was so happy when I finally scored one.
  18. Jan 6, 2016 at 9:03 AM
    #158
    gibby11
    gibby11 Well-Known Member
    Andrew
    Las Vegas, NV
    2nd gens are better, change my mind.
  19. Jan 6, 2016 at 10:32 AM
    #159
    sapperguy
    craig
    09 SR5 DCLB
    I know a couple of people have swapped clock for non-clock. Would the clock from a 2009 work in a 2015?
  20. Jan 6, 2016 at 11:03 AM
    #160
    shakerhood
    Southern Ohio
    Yeah I think it will work but it doesn't match the rest of the dash or instruments.
