Does anyone else have this problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bp_phil16, May 23, 2010.
  1. May 23, 2010 at 5:35 PM
    bp_phil16
    bp_phil16 [OP] Well-Known Member
    Arizona
    Bad Ass 06 4x4 Silver 4 Door Tacoma
    17'' Robby Gordon Wheels 33'' All-Terrain T/A Volant Cold Air Intake Magna Flow Exhaust URD MAF Limo Tint Billet Grill 3 HID's Behind Grill Headlight HID's Foglight HID's Tc UCA Kings in front and rear White face with blue needles; guage cluster Xm Radio Pioneer Double Din Deck Back Up Camera Navigation Amped Alpine Speakers 2 JL Audio 10's(Behind Seat) 2 Alpine Amps(Behind Seat)
    My front tires dont sit perfectly straight. The bottom of the tires angle in on both sides. I currently have a spacer on the front, maybe this is causing it? Im getting mid travel put on here in a few weeks, will this fix it or what could the issue be?
  2. May 23, 2010 at 5:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You need an alignment
  3. May 23, 2010 at 5:38 PM
    josep
    josep Member
    pretty sure all front tires tow in a little ( engine weight ))
  4. May 23, 2010 at 5:39 PM
    bp_phil16
    Arizona
    Ive an alignment 2 times now thinking the first time it was wrong but it still didnt solve the problem?
  5. May 23, 2010 at 5:39 PM
    jandrews
    '09 FourDubDee TRD OR
    It's wheel camber. Toyota's factory alignment "tolerances" allow for some mildly positive to mildly negative camber.
    Get an alignment done to have it corrected. Shoot for 0 camber.
  6. May 23, 2010 at 5:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im guessing your running a lift and no aftermarket UCA's?
  7. May 23, 2010 at 5:41 PM
    bp_phil16
    Arizona
    I have spacers in the front. Im getting UCA's and icon coils in the front here in a few weeks. Will this fix it after getting an alignment also?
  8. May 23, 2010 at 5:43 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Get an alignment done after your coils and UCA's are installed .
  9. May 23, 2010 at 5:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. It should.
  10. May 23, 2010 at 5:44 PM
    bp_phil16
    Arizona
    Thanks! What causes the tires to sit like that?
  11. May 23, 2010 at 6:04 PM
    jandrews
    ...they are aligned for positive camber.
