Does anyone have a pic of...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bayou2coma, Jul 17, 2007.
  1. Jul 17, 2007 at 9:08 AM
    Bayou2coma
    Bayou2coma [OP] Active Member
    Does anyone have a pic of there tacoma with:
    Some kind of leveling kit, with nothing done to the rear. Something like, adjustable front shocks or 2" spacers, with 265/70-17s?
  2. Jul 17, 2007 at 5:40 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Bilstein 5100 shocks in the front are adjustable and will help level out your truck.
  3. Jul 17, 2007 at 7:41 PM
    nceguystaco
    nceguystaco Well-Known Member
    becareful using 265 70 17 i have a 3" lift and i do have a rubbing when backing up and turning right slot uses same tire no lift and rubs at certain points but dont remember where he said it rubbed hope this helps
  4. Jul 17, 2007 at 7:51 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    you can actually lift level the front just fron the shocks? how?? lol...i'm nowhere close to understanding the suspension of the taco...
    and is there actually that much difference between the 65 and 75 series tires?
  5. Jul 17, 2007 at 7:55 PM
    nceguystaco
    with bilstien 5100 you can turn it to adjust high or low hard to explain kinda of like a big nut that you turn
  6. Jul 17, 2007 at 8:10 PM
    The_Hodge
    SC
    hmm...i may have to try that
  7. Jul 17, 2007 at 8:14 PM
    nceguystaco
  8. Jul 17, 2007 at 8:22 PM
    The_Hodge
    SC
    thanks man...and i'm guessing you could do the same w/ the rear shocks? and from what i've looked up, the difference between the 265/65 and 265/70 is 27mm=1.06"...will it make that much difference?
    but more importantly, has anyone actually lifted the front by doing this? and how?
  9. Jul 17, 2007 at 8:29 PM
    nceguystaco
    not sure if rears adjust or not as far as tires not real sure just know my 265x70x17 do rub a hair
  10. Jul 17, 2007 at 11:08 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    I have no lift yet and my 265/70/17's rub only when truning hard left and hitting a bump, like a driveway or something. I've never gotten any rubbing while four wheeling and I cant see where the rubbing is so it must not be too bad. But I have 1/4 inch spacers behind my wheels to help clear the upper control arm otherwise it would rub there.
  11. Jul 17, 2007 at 11:53 PM
    humanoid
    humanoid bite me
    Sunny SoCal
  12. Jul 18, 2007 at 6:33 AM
    Bayou2coma
    Ok, so far this is what discided that I plan putting Bilstein Height Adjustable Front shocks, I don't think that there the 5100's, there at . The site says that it can be adjusted up to 2 1/2".
    Does anyone know exactly how much the front has to be lifted to be leveled?
    So, anyway, eventhough I lift the front are the 265/70-17's still going to rub? I don't think the rear would rub anywhere?
    If I put a 1" block lift on the rear and then lift level the front, should I have any problems?
  13. Jul 18, 2007 at 6:59 AM
    nceguystaco
    i have a 3" skyjacker lift came with a add a leaf for the rear i only rub a hair in reverse turning right so at 2 " u might have to put in a spacer like slot but not sure
  14. Jul 18, 2007 at 7:09 AM
    Bayou2coma
    Do you have a pic of your truck?
  15. Jul 18, 2007 at 5:18 PM
    nceguystaco
    here is a pic only one i have right now
  16. Jul 19, 2007 at 5:00 AM
    Bayou2coma
    Thanks alot that's exactly what I want mine to look. Where did you get your lift?
  17. Jul 19, 2007 at 6:34 AM
    nceguystaco
    4wheelonline.com no tax and at time was free shipping 416.00 that is with upgraded shocks for rear
  18. Jul 20, 2007 at 10:09 AM
    LM07Sport
    LM07Sport Member
    Hey Bayou -
    I think if you want to level your truck out, you will need about a 2-2.5" lift in the front. I have the 3.5" adjustable Donahoe coilovers in the front and its a bit taller in the front than the back, and i think i only have mine cranked up about 2" of the 3.5 possible. You have a 4X4 though so im not sure if they are exactly comparable. Also, alot of guys with a 3" lift run 285X70 OR 75's - i think. good luck buddy, and when you get it done post some pics!
  19. Oct 16, 2007 at 6:37 PM
    Bayou2coma
    I just got my 5100's today! I finally decided what i am going to be doing with my truck.:D
    I don't know what I should go with to level the truck yet, 2" or 2.5". Depends what looks better with 285/60-18's.:cool:
    I bought a 1" rear block spacer incase I discide to use it with the 2.5".
    Also a diff drop from toytec lifts.
  20. Nov 14, 2007 at 1:19 PM
    gcwaterski
    gcwaterski Well-Known Member
    Thats what im doing- setting the 5100's (when i get them) to 2.5" and getting either a 1" or a 1.5" block for the rear.
    I will be running BF A/Ts 265/75-16s prolly.
    I will also go ahead and put the diff drop, axle shims and carrier bearing drop kit.
    I am figuring this is gonna run be about $1350-$1400 respectively with the most expensive thing being my tires at $759 installed.
