does anyone have Aeroforce interceptor gauge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerretxx, May 24, 2010.
  1. May 24, 2010 at 9:37 AM
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    If so, how do you like it and can i see picutres of how you have it mounted?
  2. May 24, 2010 at 12:16 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I like it.
    Lotek Pillar Pod:
  3. May 24, 2010 at 12:21 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    ^Nice install. Don't suppose you have any other pictures of it? That looks really clean.
    Does it replace the whole A pillar or are they stuck on with double sided tape?
  4. May 24, 2010 at 12:27 PM
    Evil Monkey
    Robert
    Escondido, CA
    That's the only picture I have. It replaces the whole A pillar and uses the stock grab handle.
  5. May 24, 2010 at 12:56 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Is the fit comparable to OEM?
  6. May 24, 2010 at 1:15 PM
    Evil Monkey
    Robert
    Escondido, CA
    It's pretty good. It doesn't go on as smoothly as the oem but I got it to look right. Also, the color on the grey is a pretty good match but the pattern on the surface doesn't match the oem pillar. If you compare it with the passengar pillar, you can see the difference, but it's not noticable otherwise.
  7. May 24, 2010 at 1:17 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Overland Build
    Millions
    Evil_Monkey? What gauges did you put in your cluster? It looks good.
  8. May 24, 2010 at 1:26 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    have it and like it!
  9. May 24, 2010 at 1:47 PM
    Evil Monkey
    Robert
    Escondido, CA
    The top one is the Aeroforce Interceptor gauge. The bottom one is the Whistler Fusion Radar detector. I plan to install on-board air eventually so I'll probably replace the radar detector with an air pressure gauge.
  10. May 24, 2010 at 1:48 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    Millions
    Very good. Thanks. :)
  11. May 24, 2010 at 2:54 PM
    jerretxx
    Jerret
    North Carolina
    now it does just plug into OBD connector. Also which gauge do you have the CNI or ISO?
  12. May 24, 2010 at 3:19 PM
    Evil Monkey
    Robert
    Escondido, CA
    CNi. And yes, it just plugs into the ODB connector. Aeroforce has an application guide on their site as well as a vendor presence on Tacomaworld (forcefedjunkie).
    http://www.tacomaworld.com/forum/aeroforce-technology/
    You might browse through the forum section and make sure there are no issues with your truck (year).
    http://www.tacomaworld.com/forum/group-buys/68913-aeroforce-interceptor-group-buy.html
