Does anyone have any tips or advice for installing 1.5" lift (Bilstein 5100's)?
Discussion in 'Suspension' started by Trucks4ever, Mar 31, 2017.
  1. Apr 19, 2017 at 2:39 PM
    #61
    Trucks4ever
    Trucks4ever [OP] Active Member
    Orygun
    2016 TRD Sport 4WD AT DCLB (BBP)
    It's great to see so many different opinions on how to achieve a mild 1.5" lift, seems like a few people have done the same way I was planning and are happy with the results. I appreciate everyone's comments.
    A lot of people were slamming the 1.5" lift blocks option for the rear so I have started to lean toward a single AAL from Icon or Deaver. My main concern is making the ride quality go to hell if using the AAL, she rides so smooth right now... I dont' and won't do any serious off-roading so there is no real need to go with the progressive AAL. I will likely haul heavy loads very infrequently like dirt or bark dust, general yard junk, and I have a long bed model so I think I should leave the overload spring in.
    [2016 TRD Sport, double cab, long bed]
    Plan B:
    5100 adjustable front struts (24-263108) set to 1.55" (4th notch)
    5100 standard length rear shock (24-186728)
    Deaver AAL 1.5" to 2" rear lift
    Does anyone have anything good or bad to say about this?
    Anyone with same hardware installed?
    Am I missing any parts or will this be everything I need to do the 1.5" lift all around?
    Thanks again for the comments and ideas! You guys rock!
  2. Apr 19, 2017 at 2:54 PM
    #62
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    If you want to maintain or improve upon rear ride quality do not do blocks or spacers and I'd avoid a Single AAL. The Progressive 3-leaf AAL is made specifically for achieving this goal (lift and maintaining near factory ride quality).
  3. Apr 19, 2017 at 4:04 PM
    #63
    Trucks4ever
    Orygun
    Hey Smitty, thanks for all the input. I see a lot of different opinions on greasing or not greasing between the leafs on a progressive pack, seems like a good quality progressive pack would have spacers...
    Now I am trying to sort out the real difference between progressive AAL from Icon, Deaver, Headstrong, Wheelers. I don't mind paying a little extra for quality but if it is only a name for more $ then F-that.
  4. Apr 19, 2017 at 4:18 PM
    #64
    smitty99
    Scottsdale
    Yep the 3 leaf progressive all made by Deaver to my knowledge. See aal grease method in the lift write up I did AAL portion. Link in sig
  5. Apr 19, 2017 at 4:30 PM
    #65
    odiesplace
    odiesplace Well-Known Member
    Michael
    Oregon
    95 Tacoma
    Stupid question. What is the no compression method? I bought 5100's in springs set at the highest setting, I would like to lower them a little
  6. Apr 19, 2017 at 4:33 PM
    #66
    smitty99
    Scottsdale
    See my sig for write up which has video to explain it
