does anyone have the -10 offset 17" countersteers on their unlifted truck?
Discussion in 'Wheels & Tires' started by builthatch, Apr 12, 2011.
  1. Apr 12, 2011 at 9:01 AM
    builthatch
    builthatch [OP] MiG-21 superfan
    Tony Mandarich
    near the ocean, NJ
    '11 SSM SR5 6 speed 4x4
    Hella DOT wattage high performance 9003 headlight bulbs, Optilux by Hella XY h10 fog light bulbs, Suntek HP50 tint, AFE Stage II Si intake
  2. Apr 12, 2011 at 9:13 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
  3. Apr 12, 2011 at 9:16 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    oops, sorry! yes, 17x8 type x, -10. works out to ~4" BS as far as i can tell.
  4. Apr 12, 2011 at 9:19 AM
    TexasTacoma37
  5. Apr 12, 2011 at 9:20 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Updated. :)
  6. Apr 12, 2011 at 9:27 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    yep, vermintrex is the reason i am hesitant, that thread. that is why i was curious about if i changed the tire size vs. what he had would it prevent the rubbing. he had to lift to prevent rubbing and was running 265/70/17, but i was proposing 265/65/17. that would make the tire ~.5" further away from whatever would rub. this whole thing sucks because i can't get a similarly styled wheel and i've been waiting since i bought the thing last year. rota, konig...volk. no luck in getting much, especially in bigger than 16" and in that style.
    thanks ; )
  7. Apr 12, 2011 at 12:41 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    k so it seems running the OE TRD sport tire size 265/65/17 is the key to having these work without issue on an unlifted truck.
    dustin confirmed this.
  8. Apr 12, 2011 at 8:09 PM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    I dunno about 265/65/17's but mine rubbed badly with 265/70/17's and the Type X BEFORE getting lifted, bad enough that I'd want to be able to try 265/65's on the Type X before I committed to them.
    Now that I'm lifted they don't rub at all except in reverse at almost full lock. Not bad enough that I've felt like trimming, but that may change once I get off-road this summer.
  9. Apr 12, 2011 at 9:01 PM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    thanks for your input. i can understand your concern.
    i spoke with dustin again and he assures me (several times, actually) that with no lift i will not rub whatsoever with the 17x8 -10 if and only if i stick to the OE TRD Sport tire size. i don't have front flaps but he said with that tire size i don't even have to remove flaps.
    we'll see!
  10. Apr 13, 2011 at 8:08 AM
    vermintrex
    Vancouver
    TRD SPORT Shorty
    Dustin probably knows better than me...you probably won't have any trouble.
    Good luck
  11. Apr 13, 2011 at 9:48 AM
    builthatch
    Tony Mandarich
    near the ocean, NJ
    thanks dude. yeah it's the tire size with that particular fitment that is so crucial. i'll let you know how this piece turns out.
