does anyone have this procomp?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jerretxx, Dec 16, 2010.
  1. Dec 16, 2010 at 4:09 PM
    jerretxx
    jerretxx [OP] Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    If so, what tire size are you running, and what is the ride quality. I have rough country spacer lift, and it rides terrible and my 265/70/17's still rub, THANK YOU
  2. Dec 16, 2010 at 5:05 PM
    Bsly862
    Bsly862 Well-Known Member
    Nate
    Denver, CO
    08 Off Road
    3in lift
    Ummm...
    Picture doesn't work?
  3. Dec 16, 2010 at 5:17 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    I used to run that lift and I could not stand it. Rides super rough and I felt as though I had no down travel. I would not get it.
  4. Dec 16, 2010 at 5:18 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    Can't see!
  5. Dec 16, 2010 at 5:22 PM
    jerretxx
    Jerret
    North Carolina
    can you see it now?
  6. Dec 16, 2010 at 5:25 PM
    jr114
    Jon
    SoCal
    Truck
    ya iirc procomp said that its a 718# spring rate. its meant to provide lift with an aftermarket bumper and winch. so basically its meant for an extra 100+ lbs up front. it rode very stiff. i was afraid i was going to break something going over speed bumps let alone off road.
  7. Dec 16, 2010 at 5:28 PM
    silver streak taco
    silver streak taco Well-Known Member
    I guess you are talking about the 3" spring lift with add a leaf (picture doesn't work)... I've had mine for about 2yrs and it ride's very rough but i do have 20's (305 50 20 terra grapplers, wheels are bmf's with 0 offset) so that makes it a little rougher. i only had to cut some inner fenderwell plastic in front. i am probably going to do away with the add a leaf cause it rides so rough until i get new leaf springs and i'm going to get fox coilovers soon too.
    i will definitely go to a 33 1250 next time and you could easily fit that with very minor trimming
    ps: i have 5100's in the back and i do live on about 4 miles of dirt/washboard roads so that really makes it rough but even on the street it still rides stiff
  8. Dec 16, 2010 at 5:28 PM
    Aztacotrd
    Aztacotrd Well-Known Member
    Austin
    Az
    O8' V6 Prerunner Accesscab
    My buddy has this lift on his dc. It rides like shit but I think it would ride better than a spacer lift. He paid like 500$ for it I think.
  9. Dec 16, 2010 at 5:30 PM
    jerretxx
    Jerret
    North Carolina
    so with this left i should have no problem clearing 33x12.50's, and I am planning on putting arb style bumper that my buddies fab shop is designing, here is a same
  10. Dec 16, 2010 at 5:32 PM
    justin14200
    justin14200 frequent reader
    justin
    baton rouge
    2010 prerunner sr5 bsp
    stock
    dont get it!!!! i have it. my rack and pinion died after 4000 miles....
  11. Dec 16, 2010 at 5:36 PM
    jerretxx
    Jerret
    North Carolina
    what is a good 3" lift where i can clear 33x12.50 tires that wont kill my pocket?
  12. Dec 16, 2010 at 5:36 PM
    silver streak taco
    you can easily clear 33 1250's with the right offset and also the coils were a bitch putting on the struts
  13. Dec 16, 2010 at 5:37 PM
    justin14200
    justin
    baton rouge
    stock
    camburg spindles.i wish i wwould ave done that the first time around...
  14. Dec 16, 2010 at 5:38 PM
    Unknown
    Brian
    Los Angeles
    Unknown
    Unknown
    I got the procomp coilovers with 33x12.5 bfgs.
  15. Dec 16, 2010 at 5:40 PM
    jerretxx
    Jerret
    North Carolina
    i thought you could only do those on a prerunner? will it work on 4x4?
  16. Dec 16, 2010 at 5:43 PM
    Halo913
    Halo913 Well-Known Member
    Adrian
    Tucson AZ
    Tacoma sport 4x4
    Pro-comp full suspension 3 inch lift, Built right UCA's
    I have the set up and it doesn't ride rough at all. Just got it so maybe the company recently changed something?
  17. Dec 16, 2010 at 5:44 PM
    jerretxx
    Jerret
    North Carolina
    what tire set up are you running?
  18. Dec 16, 2010 at 5:45 PM
    Halo913
    Adrian
    Tucson AZ
    Tacoma sport 4x4
    Did you also get the drop differential and sway bar extensions?
  19. Dec 16, 2010 at 5:47 PM
    justin14200
    justin
    baton rouge
    stock
    ohhhh, no it ont work
  20. Dec 16, 2010 at 5:47 PM
    jerretxx
    Jerret
    North Carolina
    i didn't think it would, thanks for the tip though
