Does anyone know why Tacomas and FJs...
Discussion in '1st Gen. Tacomas (1995-2004)' started by spidy3, Feb 24, 2011.
  1. Feb 24, 2011 at 11:52 AM
    spidy3
    spidy3 [OP] Well-Known Member
    Dom
    Upstate NY
    10 DC TRD Off Road
    Anyone know why just the manual Tacomas and FJs have the clutch cancel switch?
    I just found out, just wondering if anyone else does
  2. Feb 24, 2011 at 11:56 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    if your clutch fails, you can start the vehicle in gear and shift clutchless to get home.
  3. Feb 24, 2011 at 12:34 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '04 Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Dorkel
    I use it to start the truck when I am not in it usually. Pull p-brake, put in neutral, and turn key with button pushed...
    I think it's very convenient and Toyotas have had it for a while now.
  4. Feb 24, 2011 at 12:41 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    x2
  5. Feb 24, 2011 at 12:45 PM
    Manwithoutaplan
    ID
    I love this button. I use it all the time. When i want to warm up my car hit the button and turn the key. Bammmm it up and running.
  6. Feb 24, 2011 at 12:49 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    That's a pretty clever gambit. By using this technique, you immediately got the right answer to your question on the very first reply - as opposed to the usual litany of five or six posts telling you to search, rtfm, etc... before someone grudgingly coughs up the answer. ;):D
    RelentlessFab likes this.
  7. Feb 24, 2011 at 2:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/2.37" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Magnaflow Hi-Flow CAT, Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The validity of your comment is questionable.
    The clutch start cancel switch does not replace clutch function. All this switch does is bypass the requirement of the pedal being fully depressed to be able to start the engine. You've always been able to drive home not using a clutch, whether you use this button or not, though I wouldn't recommend it.
  8. Feb 24, 2011 at 2:53 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    or just step on the brake pedal.
  9. Feb 24, 2011 at 3:42 PM
    Digiratus
    Roaming the PNW
    The RedHead
    ^^^Would you use your left foot or your right foot to step on the brake?
    In those circumstances, with a manual trans, on a steep incline, and having to start the engine while you hold the truck in place, you have three pedals to deal with.
    The clutch start cancel switch allows you to use your left foot for the brake and your right foot for the accelerator pedal.
  10. Feb 24, 2011 at 4:34 PM
    Leggo
    Newton,Ma.
    I am no trying to be a wize ass, but I don't pump the gas in my fuel injected truck to start it. I also have a parking brake that needs no foot on it at all to hold my truck still. I just think it makes more sense for it to let one start the truck without having to get in the truck. Maybe I am wrong, but I don't need it to help start while being on a steep hill is all.
  11. Feb 24, 2011 at 4:35 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    glad you got the answer.
    i wouldnt have told him to search; i would have told him to post in the appropriate forum.
  12. Feb 24, 2011 at 5:17 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Does anyone know how it works? I have always wondered? :confused:
  13. Feb 24, 2011 at 5:30 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    Clutch Cargo?
  14. Feb 24, 2011 at 5:44 PM
    Leggo
    Newton,Ma.
    fair enough. Neutral safety switch solves that problem. I still don't get the hill start thing, but ,,ok
  15. Feb 24, 2011 at 5:53 PM
    tc98tacoma
    tc98tacoma Well-Known Member
    Nik
    San Antonio, Texas
    98tacoma4x4
    3inch toytec coils 5100's, aal(soon to be replaced), 33/12.5 km2s, + a money hole...
    you jsut gotta be quick and good at using manual trans offroadin
    just make sure no ones behind you lol
    i love the clutch cancel button !!!!!
  16. Feb 24, 2011 at 6:00 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    Yeah I don't get what some of you are talking about! You cant start the truck in gear with the clutch out! You can use it to crawl up a hill but you will likely blow the starter, and will not actually start. I did it once with an older car.
    I use it to start the truck quick from outside the truck. Yes people do jump thier trucks into sh#t doing it but you have to forget to put the break on and forget to take it out of gear, so to those people, you might want to get an auto. Anyways, everyone I know who drives stick uses the ebrake every time they park. Too easy to nock it out of gear.
  17. Feb 24, 2011 at 6:13 PM
    Leggo
    Newton,Ma.
    I can start the truck with my left foot on the clutch, my right foot on the brake. I won't roll back or forward now while I start the truck. When it's started, I can switch my right foot to the gas pedal while I ease the clutch pedal out, in gear of course, to get the truck moving again after a stall (simple hill start). I hope this clears up the issue of not needing it to be able to start the truck on an incline.(steep or not) Fuel injected cars and trucks don't require pumping of the gas pedal to start UNLESS you already pumped it and flooded it. Then you hold the pedal down to the floor until it starts to clear the flood. I can do that with my foot on the gas and another on the clutch with my e-brake engaged, without rolling. What am I missing here?
  18. Feb 24, 2011 at 6:21 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
  19. Feb 24, 2011 at 6:24 PM
    Leggo
    Newton,Ma.
    lol. your alright bud..I been there.
  20. Feb 24, 2011 at 6:28 PM
    MQQSE
    MQQSE Bannable Galloot
    Rob III
    Palmer, Alaska
    "Stitch" Still Stock Concept Truck
    Shtuff
    I believe you're correct...but for the record: winter in Alaska we don't leave vehicles parked with the ebrake on; they've been known to freeze up. Surprised that isn't a possibility in Connecticut as well.
    So my procedure is 1) set ebrake 2) shift to neutral 3) push clutch cancel button 4) start truck. I like having the button when you need to clean off the truck, scrape frost, etc.
