Does anyone know why Tacomas and FJs...
Discussion in '1st Gen. Tacomas (1995-2004)' started by spidy3, Feb 24, 2011.
  1. Feb 24, 2011 at 7:11 PM
    Leggo
    Leggo slow is smooth, and smooth is fast.
    Newton,Ma.
    10 TRD Sport AC 4x4 MGM
    Kenwood HU,Infinity Kappa speakers (x4), Infinity reference tweeters(x2),10" Kicker sub, Box by Subthump, Infinty Five channel amp,DVD anytime bypass, DTRL Mod, Xtang trifecta, Fogs anytime Mod, Bed Mat,Westin running boards, Console vault, Maglite mod, Weathertechs,Autopage remote starter, Power tailgate lock, HID Bi Zenon, Hella Supertones,Rain guards,Rear leaf TSB,Steering shaft TSB, Fisher Homesteader plow, 886 reverse lights mod, Redline Hood struts, Hankook Dynapro ATM LT265/70R17, power sliding rear window, Auto dimming/on anytime Bed lights, Blue Sea fuse panel & 100amp Breaker, de- badged,Rear headrest's removed, imMrYo mirror relocation,Homeroshi grill
    Well, after searching "other" forums on the subject, It seems a fair argument can be made for both reasons, as well as here. I can see being in 4lo and 1st gear and using the switch to start the truck in gear to crawl out of a sticky spot(and it will start in gear). It also seems a very rare spot to be in to me. I would get more out of it by using it to start the truck from outside the door myself. It seems a dual function switch at the least. I drive an automatic so I have no trouble either way. Amazing what they will think of next!
  2. May 5, 2015 at 1:49 PM
    armyofsquirrels
    armyofsquirrels Embrace the Suck!
    Chip
    Sykesville MD
    2015 V6 6Spd Tacoma DCSB Offroad in Pyrite Mica
    See Build Page.
    Just for the record you CAN start the truck in gear if the Ebrake is not on. Albeit a pretty rough start, it will start without stalling. Tested in a 12 4cly on a very slight incline. I never knew this is what it was for I always assumed it was so you could start the truck without having to get inside and push the clutch in.
  3. May 5, 2015 at 5:58 PM
    Madjik_Man
    Colorado Front Range
    Some of us are equipped with a third leg
  4. May 5, 2015 at 9:14 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    I once used my clutch cancel
    to start my rig/rolling in first gear multiple times
    simple turn of the key 5sp manual does it.
    I had to shift clutch less from DownTown San Diego to Oceanside (mostly freeway)
    due to a hydraulic failure once.
    Stop and go was a bitch I do remember...
    But I got it done.
    I've used it off road as well...
    tho' no real advantage that I see
    so my CC normally is ignored.
    I would think a manual trans
    would benefit with having more beneficial purposes
    then what an auto might offer.
    But then... I don't have an auto
