Does anyone make a Sway Bar Extended Link?
Discussion in '1st Gen. Tacomas (1995-2004)' started by gsrogers, May 11, 2020.
  1. May 20, 2020 at 6:15 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Found the listed on ebay a few bucks cheaper.
    I'll post the link.
  2. May 20, 2020 at 6:16 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    tony2018 likes this.
  3. May 20, 2020 at 7:38 PM
    gsrogers
    gsrogers [OP] 2003 TRD 4X4
    Garry
    Friendswood Texas
    2003 Tacoma DC TRD 4X4
    Fabtech 6" with Alcan 6" rear springs 33" Nitto Terra Grapplers
    UMMMM,....not sure shipping from Australia will make it cheaper.
  4. May 20, 2020 at 9:09 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    I'm looking to order next month. Taking care of rack and pinion bushings first and Tundra Brake Upgrade this month
  5. May 21, 2020 at 11:52 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  6. May 31, 2020 at 6:55 AM
    sowlescodey
    sowlescodey Well-Known Member
    07 tacoma double cab
    leveling kit, wheels, tires, light bar, back rack, toolbox, tinted windows, smoked lights
    What year and model is the truck you installed these on.
  7. May 31, 2020 at 7:12 AM
    gsrogers
    Garry
    Friendswood Texas
    I have a 2003 Double Cab but the main thing is I am running a 6" Fabtech lift.
  8. May 31, 2020 at 8:47 AM
    Madjik_Man
    Colorado Front Range
    For what it’s worth I did the same and immediately connected everything back up after my first trip into the mountains.
    Kind of an odd feeling when you feel like you’re gonna crap your pants with a puckered a-hole.
    Yes the absorption of bumps was very nice however the body roll going up/down mountain passes at 75 mph was scary.
    Maybe in TX you don’t experience it that much (if it’s flat)
    15psd likes this.
  9. May 31, 2020 at 8:52 AM
    3roguen
    3roguen Well-Known Member
    Evan
    Altoona, PA
    06 SR5 4x4
    4th and D
    You need the sway bar relocate from wheelers. Moves the entire sway bar an inch forward.
  10. May 31, 2020 at 8:55 AM
    gsrogers
    Garry
    Friendswood Texas
    In the end I kept the sway bar and bought those extensions. All working nice.
    Madjik_Man[QUOTED] likes this.
  11. May 31, 2020 at 8:56 AM
    gsrogers
    Garry
    Friendswood Texas
    Check out my build....the Fabtech lift has lowering and relocating brackets but it was not enough. The extensions fixed my problem. See pics above.
  12. May 31, 2020 at 3:55 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    The extended sway bar links move the sway bar back to the correct location and plane. So moving the sway bar down and forward 1 inch is not necessary.
  13. Nov 11, 2021 at 12:05 PM
    BeastyDirtSlut
    BeastyDirtSlut Well-Known Member
    2003 Toyota Tacoma 4x4 TRD SR5 3.4 Auto
    2nd Gen Supercharger, URD 7th injector, 6" Fabtech lift, King coilovers, Alcan lift springs 800# over
    Sorry to bring this back from the dead but I have a fabtech 6" on my truck and want to put the sway bar back on it. I would like to remove the lifts drop block and use extended links. Did you keep the block or remove it?
  14. Nov 11, 2021 at 2:49 PM
    gsrogers
    Garry
    Friendswood Texas
    I kept the sway bar drop brackets and added the extended links in this thread. Works great
    BeastyDirtSlut likes this.
  15. Nov 11, 2021 at 4:49 PM
    #35
    BeastyDirtSlut
  16. Dec 11, 2024 at 7:24 AM
    #36
    taco-or-not-go
    taco-or-not-go Member
    Enzo
    Charlotte, Vermont
    '01 Tacoma Xtra Cab TRD
    Toytec 3" 5100's, Steel Wheels
    Just ordered a set of those superpro's, was going to get some TRQ's or something that were $150 so these saved me some money and pain in the balls. Thanks for the suggestions
  17. Dec 23, 2024 at 7:16 PM
    #37
    15psd
    15psd Member
  18. Dec 23, 2024 at 7:36 PM
    #38
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    15psd[QUOTED] likes this.
  19. Dec 25, 2024 at 5:38 PM
    #39
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    I’ve got these installed. So far so good.
