Does anyone make bearing assemblies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Owenhall, Oct 2, 2024.
  1. Oct 2, 2024 at 7:46 PM
    Owenhall
    Owenhall [OP] Well-Known Member
    Owen
    2009 Toyota Tacoma 4x4
    Lift 33s
    Does anyone make wheel bearing assembly’s using oem bearings Looking for 2 new front hubs and bearings and 1 new rear bearing.thought I saw a thread on this a while back.
  2. Oct 2, 2024 at 7:48 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    For the front:
    https://www.tacomaworld.com/threads/wheel-bearings-hubs-press-service-oe-nsk.537080/#post-17293000
    The rears are very expensive and sold by Toyota as one piece ready to install. You can get some aftermarkets but not a lot of options exist for that and who knows if they’re any good. A lot of work to swap them to find out if they suck. Probably better off spending the $300 on OEM per side. If you’re doing the work yourself, you need a special puller tool for Toyota axles, and a press that is wide enough in the press apron to fit said tool.
  3. Oct 2, 2024 at 7:49 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
  4. Oct 2, 2024 at 8:00 PM
    Owenhall
    Owen
    Lift 33s
    I already have the tool and did one side on the rear axle.the other side feels smooth and doesn’t have play currently but I would like to replace it as well as the fronts this year for preventative maintenance .
  5. Oct 2, 2024 at 8:03 PM
    Owenhall
    Owen
    Lift 33s
    I don’t know about the fronts I think I can preswade those off with a large hammer.
  6. Oct 2, 2024 at 8:06 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The rear bearing is no fun.
    You need a special jig to press it on.
  7. Oct 2, 2024 at 8:17 PM
    Owenhall
    Owen
    Lift 33s
    I know I did one of the rear ones it was a pain.how are the front bearings.
  8. Oct 2, 2024 at 8:18 PM
    BLtheP
    Plano, TX
    Easy, like installing any normal front unit bearing. That is, assuming you buy them pre-assembled like from the guy in the links above or similar.
    Superdave1.0 likes this.
  9. Oct 2, 2024 at 8:30 PM
    Owenhall
    Owen
    Lift 33s
    His link says unavailable.
  10. Oct 2, 2024 at 8:33 PM
    BLtheP
    Plano, TX
    It says unavailable on pre runner, but your profile says 4x4 so I assumed you’d be good to go.
  11. Oct 2, 2024 at 8:36 PM
    Owenhall
    Owen
    Lift 33s
    O I was looking at the wrong part
  12. Oct 2, 2024 at 8:39 PM
    Owenhall
    Owen
    Lift 33s
    Does he have any rear wheel bearings the one side I replaced with one from the parts store and it was expensive.
  13. Oct 2, 2024 at 8:51 PM
    TnShooter
    Deogee
    STOCK
  14. Oct 2, 2024 at 9:37 PM
    Owenhall
    Owen
    Lift 33s
    I have already done the drivers side rear bearing just didn’t do both only one was bad just want to replace the passenger side one soon as preventative maintenance.
  15. Oct 2, 2024 at 11:50 PM
    FJC MAN
    FJC MAN Active Member
    Bill
    2007 FJ Cruiser
    yotabearingsandhubs.com for the best price for front bearing assemblies.
  16. Oct 3, 2024 at 10:08 AM
    Owenhall
    Owen
    Lift 33s
    Are These bearings are abs compatable.
