Does lifting void the warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TimmyC, Apr 3, 2017.
  1. Apr 3, 2017 at 6:15 PM
    TimmyC
    TimmyC [OP] Well-Known Member
    Tim
    Central MA
    2017 TRD OR DC Long Bed
    Billstein 5100's, OME 888 Coils, Dakar Medium Duty Leaf Pack, SC Ray Rims, BFG K02 - 285's, Leer XR100 cap, Topper EZ Lift System
    Hi everyone,
    I've had a Tacoma boner for the last few years and I'm finally pulling the trigger on 2017 TRD Off Rod double cab long bed in silver. Going for the fully loaded version with premium tech package. This will be our 3rd vehicle and not my daily driver. I want to lift it, but in speaking with the Toyota salesperson today he said it could void my warranty. Is this true? Is there a way to lift it that will not void the warranty?
    Thanks,
    Tim
    NickleCityTaco likes this.
  2. Apr 3, 2017 at 6:19 PM
    10tacosr5
    10tacosr5 Well-Known Member
    Washington Twp, South NJ
    2010 Tacoma SR5 DCLB
    5100s/Headstrong Coils/Deaver AAL/Level8 MK6/FalkenWildpeakAT3
    Where I work at honda it only voids the warranty on that part that is changed out. So if you change out your suspension and your motor blows up, your fine. If you change out your shocks and they blow out and leak, they won't be covered.
  3. Apr 3, 2017 at 6:21 PM
    RedAlertCA
    RedAlertCA I like her a little dirty.
    Rob
    Sonora CA
    2016 DCLB Off Road - The most maligned Tacoma ever!
    Rockford Fosgate all around AllPro Differential/Exhaust Skid AllPro Apex Sliders
    The service manager at my Toyota dealer said they warranty service lifted trucks all the time, and that they only have an issue if the lift is affecting the problem. This also seems to be the common wisdom on TacomaWorld. People also often say that the dealership has to prove that you voided your warranty in order to deny your service, but they are much better at making this a big hassle then you are at fighting it.
    securekey likes this.
  4. Apr 3, 2017 at 6:35 PM
    Absolute Zero
    Absolute Zero Well-Known Member
    Check out the Magnuson-Moss Warranty Act.
    Warranty can only be denied if you modify something that causes/relates to the failure.
    Of course the stealership will try to prove your lift caused everything to fail.
  5. Apr 3, 2017 at 6:36 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    It can void the warranty on any failure that touches the modification or could be reasonably considered to be impacted by the modification. It doesn't void the entire warranty. If your radio goes out they can't blame the lift. If you lift the truck 3 inches and the carrier bearing takes a shit or the transmission fails they may likely blame the lift and thus void the warranty coverage for your tranny. Magnuson Moss act means jack shit. The dealer can tell you to pound sand and what will your recourse be? Do you have time and money to get lawyers to fight? Most dont.
    davidstacoma, Storman, Garyji and 9 others like this.
  6. Apr 3, 2017 at 6:46 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Smitty you sound just like me "pound sand" been using that for 40 years, i would add the OP's warranty could turn into a real goat rope. do not think i would want to get wrapped around the axle with the dealer because of lifting it.
    ZachMX and smitty99[QUOTED] like this.
  7. Apr 3, 2017 at 6:51 PM
    erok81
    erok81 Well-Known Member
    Imposter
    :rofl::rofl::rofl:
    George1441 and smitty99 like this.
  8. Apr 3, 2017 at 6:52 PM
    PvilleJohn
    PvilleJohn SVT Raptor
    Powdersville SC
    SVT Raptor
    Already been down this Road on my 2016. Only thing that's voided is the item that's changed out. And like a few others have stated....depending how your dealer is...if your coilovers are set at the highest notch and you wear out a CV axle.....they're probably going to fault the lift and it won't be covered.
    Best bet if your concerned about it, let the dealer install the lift. Obviously more money out of pocket but at least there's no question of what's covered.
  9. Apr 3, 2017 at 7:06 PM
    securekey
    securekey Well-Known Member
    2018 TRD Off-Road DCSB - Blazing Blue
    What redalertca, smitty99 and pvillejohn said is accurate. There really isn't anything else to add..
    George1441 likes this.
  10. Apr 3, 2017 at 7:09 PM
    Bishop84
    Bishop84 Well-Known Member
    I have yet to void any major components due to a lift. But if you want to be sure, have the dealership lift it for you, placing the ownness on them.
    EnragedMedic likes this.
  11. Apr 3, 2017 at 7:10 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Only voids the suspension part of your warranty
  12. Apr 3, 2017 at 7:48 PM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    What @Bishop84 said, order yoir lift parts etc and have the dealer install... or get them to price match and do it.
  13. Apr 3, 2017 at 7:51 PM
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    The simplest thing is learn to wrench, lift truck, keep stock suspension and go back stock if problems occur.
  14. Apr 3, 2017 at 8:09 PM
    TurnLeft
    TurnLeft Well-Known Member
    2017 MGM DCSB SR5 V6
    Exactly. I got all the stock parts on a shelf in the event I have to go back to stock. Should be quicker installing the second time around
  15. Apr 3, 2017 at 9:26 PM
    Broccoli
    Airdrie Alberta
    My only thoughts on that process is if you have the truck lifted, take it in for a differential issue for example, they say its lifted. Put it on the work order and then you bring it back stock?
    Unless u plan on returning it to stock every time you take it to the dealership...
    bobrown14 likes this.
  16. Apr 3, 2017 at 9:29 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Incorrect. Per the act/law if the lift/altered part causes the issue, its not covered. So if you change the angles of your driveline, put more stress on your differential/transmission, etc. due to your lift theoretically they can deny your claim, but they have to prove it, then again you would also have to prove as to why it didnt and then ultimately they can deny or do whatever warranty work they choose. Its a gamble you're going to take.
    davidstacoma and smitty99 like this.
  17. Apr 3, 2017 at 9:31 PM
    SocalOC
    SocalOC Well-Known Member
    2015 Sport
    17" rockstart 2 levling kit 285/70/17 toyo ipen country
    I was told only voids warrantry if i went over 4" of lift
  18. Apr 4, 2017 at 7:54 AM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Do our trucks have warranties? Every time something wrong with mine its either my fault or normal. Clutch squeaks with heat on? Dont run floor heat for extended periods of time. Lca howl? Nah that isnt a thing (before tsb) hill start assist is acting up? Nah my truck might not even have it (it does) plus about 20 other squeaks and rattles but they all got blamed on either going offroad or couldnt replicate
    nevadabugle and smitty99 like this.
  19. Apr 4, 2017 at 7:56 AM
    smitty99
    Scottsdale
    Yes. Exactly like I said "It can void the warranty on any failure that touches the modification or could be reasonably considered to be impacted by the modification." So if it can be construed that the failure of a system, part or component is related to a modification....you COULD be on the hook.
  20. Apr 4, 2017 at 8:07 AM
    brich999
    Bryan
    all tore up already
    Biggest thing to remember with all this law legal bs is who you are fighting and over what. Sure if your diff grenades you wouldnt want to pay the couple grand for a new one. Thats a drop in the bucket for toyota. But them admitting issue with your truck means they admit issue with all trucks with that part. They have much more at stake and much bigger legal team than any one person does. So technically yes they will have to prove your part caused the issue but is any member here prepared to fight toyota in court? I dont have that kinda time and money
    smitty99 likes this.
