Does my S/C NEED extra gauges?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by eazyrider711, Aug 15, 2014.
  1. Aug 15, 2014 at 11:36 AM
    eazyrider711
    eazyrider711 [OP] Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
    I'm getting ready to pull the trigger on a S/C for my 2013. The only other performance mod I'll have will be the afe Pro Dry CAI. I've read a ton of posts about AFR and Boost gauges. Do I need these for a pretty much stock install? I won't be doing any fuel pump upgrades or anything else until the factory drive train warranty is expired.
  2. Aug 15, 2014 at 11:52 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    nope your good. Id even be fine with a URD stealth pully and stock everything else.
  3. Aug 15, 2014 at 12:47 PM
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I wouldn't worry about AFR and Boost gauges if you're running a stock S/C. When you start doing things like getting standalone fuel management, injectors, and tuning, that's when you'd want to get some gauges to make sure everything stays in check.
  4. Aug 15, 2014 at 1:20 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    I occasionally throw an engine code when horsing around off road, stock fuel pump can't keep up.
  5. Aug 15, 2014 at 1:26 PM
    nd4spdbh
    SoCal
    buddy o mine beats the hell out of his. stock SC with urd stealth pully... never thrown any codes.
  6. Aug 16, 2014 at 6:52 AM
    mattgecko
    South San Jose, CA
    It only happens when I do dounuts in the dirt.
    I am running Trd sc, trd cai, everything else is stock under the hood.
  7. Aug 16, 2014 at 7:07 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I would vote yes, with alot of the "reflashes" are hit or miss on whether your running super rich or right a stoich or lean unless they've fine tuned their reflash since 09 when I had mine done. I like the comfort of being able to see whether the truck is running lean or rich stock or modified. The boost and vaccum gauge helped me diagnose a vaccum leak a few months ago when I noticed the truck wasnt pulling the usual amount of vaccum with the A/C off truck never stumbled or gave a indication but I saw it on the gauge.
  8. Aug 16, 2014 at 7:15 AM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
  9. Aug 16, 2014 at 2:24 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    It's my inner need but I like more information than less.
    With add-on forced induction I'd be apt to run boost, AFR via a true add-on wideband (AEM UEGO, Innovate LC-1, etc) and oil pressure.
    If you're running an otherwise stock truck it's not necessary but it can't hurt. On my STi I have boost, EGT, oil pressure, oil temperature and wideband AFR via an AEM UEGO.
  10. Aug 16, 2014 at 2:32 PM
    eazyrider711
    Jay
    Northern, CO
    Black DCSB T|X Baja
    Thanks for all the info.
  11. Aug 16, 2014 at 2:45 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Always run an Afr gauge..... Guessing is for fools when it comes to this part.
    Boost is nice and can help u see differences in boost or vacuum over time
    The stock fuel pump drops off at high demand..... It just cannot keep up.
  12. Aug 16, 2014 at 2:47 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Remember not all reflashes are the same.
