Does my Tacoma Have Tow Package
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hahnster, Jul 10, 2023.
  1. Jul 10, 2023 at 10:08 PM
    hahnster
    hahnster [OP] Well-Known Member
    2022 Tacoma 4x4 V6 AT
    3" Lift, TRD Pro Grill, TRD Skid Plate, 285x70/r17 BFG KO2's, LED Headlights, Rock Sliders
    I have a 2023 SR SX 4wd V6 Auto tacoma. It's my understanding that all of these configurations would have the tow package as standard. I do have all of the electrical plug ins on the rear bumper. I'm Mostly asking because I want to install a brake controller and need to know if my truck will have the plug for the controller already installed.
    Thank You
  2. Jul 10, 2023 at 10:11 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    I believe so yes
  3. Jul 10, 2023 at 10:27 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    My SR5 did. Plugged into the 7-pin on the tear-drop, my controller is 12V so once plugged into the 12V it worked like a champ.
    The controller works in conjunction with the electric brake system on my teardrop - I assume your setup will be the same.
    zoo truck likes this.
  4. Jul 11, 2023 at 4:09 AM
    Old goat1914
    Old goat1914 Well-Known Member
    Chicagoland, Indiana
    2016 TRD Sport DCLB 4x4
    I understand the plug in point is on the left of the steering wheel under the dash and that it can be hard to find. There are threads here on the install of brake controllers.
  5. Jul 11, 2023 at 4:15 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    My 2013 SR5 did, I would believe that your 2023 does. I am certain my 2021 does but havent bothered to look yet tbh
  6. Jul 11, 2023 at 5:08 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Same with mine. I would think as long as the truck came with a tow hitch, its got everything else, you'd need.
  7. Jul 11, 2023 at 7:11 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    LeakyAC likes this.
  8. Jul 11, 2023 at 8:52 AM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Yes 'tow package' from 21/22 and on no longer have the aux ATF cooler, I wonder if they even have a bigger alternator anymore???
  9. Jul 11, 2023 at 12:08 PM
    zoo truck
    None
    TA2016[QUOTED] likes this.
