Does OME with dakar springs allow 4dcb to carry more weight?
Discussion in 'Suspension' started by Skip1457, Feb 19, 2012.
  1. Feb 19, 2012 at 4:42 PM
    Skip1457
    Skip1457 [OP] Member
    2011 SR5 4x4 crewcab
    4 piaa offroad lights on front,cap with complete yakima rack on top,dirt bike carrier on reese hitch,k&n air intake
    Have a base model Toyota Tacoma crew cab and is constantly
    riding on the bumper stops when loaded with cargo. Will
    adding an OME suspension with Dakar springs be stronger?
  2. Feb 19, 2012 at 4:48 PM
    TrdSurgie
    TrdSurgie revised
    SoCal
    Sounds like you need the TSB springs. Toyota puts cheap leaf packs for "customer comfort" the work is free under warrenty. Do a search for rear spring tsb and you'll find everything you need to know.
    Or you can upgrade to dakers or whatever eled
  3. Feb 19, 2012 at 4:53 PM
    Skip1457
    Thanks for the input, I'll look into that.
  4. Feb 19, 2012 at 5:10 PM
    Skip1457
    What are tsb's?
  5. Feb 19, 2012 at 5:21 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    TSB Technical Service Bulletin. These are issues that Toyota have found and will repair or replace on your truck.
    In your case, they will give you a new set of rear leaf springs to replace yours, no charge.
  6. Feb 19, 2012 at 6:24 PM
    Skip1457
    Fantastic! Thanks for your help.
  7. Feb 19, 2012 at 6:28 PM
    Brunes
    Brunes abides.
    Rotorhead
    "When loaded with cargo" How much cargo are we talking about?? Because if you have 400lbs of stuff-That is a problem. If you have 2000lbs-There is still a problem but it's not with the leaf springs.
  8. Feb 19, 2012 at 11:39 PM
    Valley Viking
    Valley Viking Well-Known Member
    Menlo, WA
    05 4x4 DC LB SR5
    OME 885 Coils, OME Dakar Rear Leafs, OME NitroCharger Shocks, LR UCA's, AFE ProDry Air Filter, Scanguage, Wet Okole Seat Covers
    I installed Dakars on my DCLB and it made a world of difference in the trucks load carrying ability. My truck would hammer the bump stops endlessly with the stock leafs. With the Dakars you can load er up with firewood, quads, demolition debris or whatever and it still sits pretty level, handles well and doesn't even get close to the bump stops. I got about 2-3/4" of lift.
    In other words I love em!
